lk3054 shifter stopped working
/ lk3054 shifter stopped working #1
66gt350
Redding, CA
Kioti LK3054
Over the weekend, the shifter on my 3054 decided to stop working. It's stuck in I believe second gear. The shifter does nothing, it's just free floating. It pulls up about 6 inches, and I can see what looks like a bolt that has sheared off. I just ordered a parts manual and service manual, but they won't be in for a week. I started to take off the cast iron plate that's on the side of the tranny, to get a look to see what's the problem, but have run into trouble. I took out all the bolts, but the plate is stuck on there. It looks like there's a sealant holding it on. Does this come off easy or will this take major surgery to fix? Does someone have a scanned copy of the parts blow up of the tranny and shifter area, so I can work on this while mine are being shipped?
edit: I went to the local dealer, which they've only been a dealer about a week, and got a blow up of the area I need. It looks like the main shift cover should come straight off. It must be held on by some sealant from hades. I guess that I'll just have to work on breaking the sealant free. Any words of wisdom?
thanks
/ lk3054 shifter stopped working #3
I believe there is a roll pin that you probably broke or came loose and that is what has your shifter lever free, seems like a common issue, but simple to fix.
Joel
/ lk3054 shifter stopped working #4
thanks
I have the same issue. Could you please explain the repair and if you were able to fix. Thank you
/ lk3054 shifter stopped working #5
I realize that you’re a new member…welcome. But this thread is from two thousand and ten so the OP may not reply. Respond with tractor model, current hours and symptoms. Hopefully someone with a similar experience can provide some insight/help for you …😉
/ lk3054 shifter stopped working #6
Hi guys,
I’ve not personally had to fix but seen similar posts.
I can provide pics of repair manual if you don’t already have
/ lk3054 shifter stopped working #7
Hi guys,
JoelD that would be very helpful. I’m reviewing the parts manual and checking out the parts that interfere. Getting ready to drain the hydraulic fluid. Thank you.
/ lk3054 shifter stopped working #8
Thread '2006 Lk3054xs, 573 hours, loose shifter. Stuck in fourth gear.'
I refreshed my request per Robin’s recommendation. If you could reply there with any advice I would appreciate it. Thanks again for responding to the post.
2022 EZ-GO ELITE...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
HEAVYEQUIPMENT TIRES (A65643)
HEAVYEQUIPMENT...
Great Plains Ultra Till 3030 (A63688)
Great Plains Ultra...
8" Mini Excavator Bucket (A66285)
8" Mini Excavator...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
