LK3054 PTO Shift Fork Replacement
/ LK3054 PTO Shift Fork Replacement #1
RobbieA
Kioti LK3054
Has anyone replaced the PTO Shift Fork on their LK3054? It looks like I need to replace mine.
If you have, did you replace it frome the reat cover or did you have to take 3 point hydraulic cylinder assembly off to get to it from the top?
I found a post about replacing a PTO Shift fork on a Kioti LK3054 but it didn't mention how it was done.
Thanks in advance.
/ LK3054 PTO Shift Fork Replacement #2
Did you find an answer for this.. I have the same tractor.. Having an issue of it not going in or out of drive on the PTO.. I'm hunting for a service manual as this and the clutch as my two winter projects....
/ LK3054 PTO Shift Fork Replacement #3
I found a post about replacing a PTO Shift fork on a Kioti LK3054 but it didn't mention how block blast was done.
Thanks in advance.
I haven’t done the PTO shift fork on the LK3054 myself, but I’ve replaced similar parts on other Kioti models. Usually, it’s easier to access from the rear cover if you can, but sometimes removing the 3-point hydraulic cylinder gives you much more room to maneuver.
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
John Deere 7410 (A64119)
John Deere 7410...
ROUND BALE HAY RING (A63291)
ROUND BALE HAY...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2014 Ford Escape SUV (A61574)
2014 Ford Escape...
