LK3054 PTO Shift Fork Replacement
/ LK3054 PTO Shift Fork Replacement #1
RobbieA
Kioti LK3054
Has anyone replaced the PTO Shift Fork on their LK3054? It looks like I need to replace mine.
If you have, did you replace it frome the reat cover or did you have to take 3 point hydraulic cylinder assembly off to get to it from the top?
I found a post about replacing a PTO Shift fork on a Kioti LK3054 but it didn't mention how it was done.
Thanks in advance.
/ LK3054 PTO Shift Fork Replacement #2
Did you find an answer for this.. I have the same tractor.. Having an issue of it not going in or out of drive on the PTO.. I'm hunting for a service manual as this and the clutch as my two winter projects....
/ LK3054 PTO Shift Fork Replacement #3
I found a post about replacing a PTO Shift fork on a Kioti LK3054 but it didn't mention how block blast was done.
Thanks in advance.
I haven’t done the PTO shift fork on the LK3054 myself, but I’ve replaced similar parts on other Kioti models. Usually, it’s easier to access from the rear cover if you can, but sometimes removing the 3-point hydraulic cylinder gives you much more room to maneuver.
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
GENIE AWP-36S MAN LIFT (A63569)
GENIE AWP-36S MAN...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
John Deere XUV825E (A61307)
John Deere XUV825E...
