Lk3054 charging
/ Lk3054 charging #1
dennbonn
Kioti lk3054
I have a lk3054 that when started battery voltage is around 13v and with idling it keeps increasing to 16+. At that point the charge light begins slowly flashing and voltage fluctuate between 14 to 16. Has a new regulator (solid state). Does this sound like a possible alternator when getting warm?
/ Lk3054 charging #2
It sounds like a bad regulator. Why was the old one replaced? Same symptoms or something else?
/ Lk3054 charging
Old one was not charging at all. Dash light on continuous
/ Lk3054 charging #4
It might be a good idea to check your chassis ground(s) to be sure they are tight and making good contact. I've seen bad ground contacts cause unusual symptoms in a couple of vehicles I've worked on in the past.
