livestock water heaters
/ livestock water heaters #1
chrisdvorak
RI
too many
I am looking for some advice on what you guys use from keeping your livestock water from freezing, i have a barn with electricity but do not want to run up a huge bill for having a heater going 24/7 and i do not have nor have the money to install a frost free hydrant. i have chickens with a self watering can and cows with a plastic tub, any suggestions?
/ livestock water heaters #2
For my goats and sheep, I use 15 gallon heated tubs that TSC has for the best price. For my horses, I use a submersable heater that I put in their 50 gallon stock tank. That's also cheapest at TSC.
/ livestock water heaters #4
The 5 gallon buckets are fine, but make sure they are someplace where the goats can't knock them over. Goats play rough with each other and can easily knock a 5 gallon bucket over, heck mine sometimes knock their 15 gallon buckets over, even when they're filled with water. Make sure the buckets turn off if the water dumps out of them. Any new heated bucket should do that, but I'm not sure about old ones.
/ livestock water heaters #5
I use floats that are heaters with thermostats.. they only run when temps hit freezing.. never had a tank freeze solid across a top yet.. always a couple foot hole around the float for the animals to drink from..
soundguy
/ livestock water heaters #6
Use a the smallest rubbermade tank and heater that installs through drain plug from TSC. Bolt the tank to a fence post on a fence line and run the cord and plug on your side.The heaters have thermostates that keep the water above 40 degrees and are inexpencive to run.Use a gruond falt plug.
/ livestock water heaters #7
I have no experience with chickens or cows. For horses, I have a 50 gal. RubberMaid tank w/drain plug heater from TSC. The entire tank sets inside an Styrofoam insulated wood box. I cut a single round hole in the box cover that accepts a cut down 5 gal. plastic bucket with a large hole cut in the bottom. I have no data on electricity savings, but I am sure the insulated box and reduced water surface exposure is reducing electricity usage, considerably. The box cover can be lifted off to clean the tank. I do have to put the bucket back into the box cover at times, as the horses lift it out when they get bored.
can you see a big difference in you electricity bill by using these heaters?
/ livestock water heaters #9
My heater is thermostatically controlled and the box has 1" of styrofoam insulation on all sides. My electricity bill averages 257 KWH higher per month during the heating months. Some of that increase is from the tank heater. Some of the increase is from three bucket heaters in an unheated barn, more lights on for more hours per day, and the furnace blower motor running more.
/ livestock water heaters #10
hello i use beat juice after boiling the beat the juice remaines i mix with water and water doesnt freeze as easy .naturaly i eat the beats and chickens love the juice.
/ livestock water heaters #11
We use these with our goats:
Heated 16-Gallon Tub - Heated Bowls
Yes, a bit pricey but well worth it. 16 gal, 250 watt, auto shut off, and tip over........
The shut off is 42 degrees which is perfect. Goats use to much energy drinking cold water and then their bodies heating it up. Kills weight gain
We have a 20 amp circuit down at the barn so my wife has to be careful as to what she uses. When it isnt COLD she unplugs them. Cold meaning low to mid 20's........
Anyway, works for us, we use 3 of them.........Dennis
/ livestock water heaters #12
Good idea!
/ livestock water heaters #13
My electric from last season on 75 gal tank with heater in bottom was dec 08-23.91 jan 09-24.82 feb-18.70 mar-09 9.42 . this is for heater only in ohio for 7 cows. I did not check the kwh.
/ livestock water heaters #14
It's not a 1500w heater like the ones you buy for your bathroom.. it just keeps the water around it just above freezing to prevent an ice over that will turn animals away.
I also install a ground rod at my tanks, and run a ground strap into the water just incase of electrical fault, as it will hit the strap not the animal, and then pop the breaker/fuse.. etc.
this can also prevent ground loops that may cause tingle.. cows usually ignore it.. but horses won't drink out of a waterer that tingles their nose/lips..
soundguy
/ livestock water heaters #15
we just had a 20 below cold snap, ended on thanksgiving. I have my horses at the inlaws, and the electric bill could be a sore topic.
I have a 160 gallon water tank in a wooden box and 4 inches of styrofoam on all sides. I have a 4 inch thick lid for 3/4 of the top, and run a thermostat controlled 1000 watt heater.
At zero the tank will take 3 days to crust over with ice
good luck
I think i will get a 16 gallon heated tank at TSC for the pasture and maybe get two smaller ones to go in both stalls and see how it goes
/ livestock water heaters #17
If you intend to hang the smaller ones on the wall, I would stabilize them with some kind of bucket holder.
For horses, I like to hang the bucket on a hook with an adjustable holder. The holder is a flat metal adjustable band that goes through a short piece of pipe welded to a flange. The flange is secured to the wall. When you pick up the bucket to clean it, the holder simply drops to the wall allowing me to dump any dirty water to another container.
The thing with horses is that you need to keep excess power cord to a limit and also cover the cord as much as possible. I don't know if cows get bored or not?
AUCTION STARTS HERE @ 9AM (A63291)
AUCTION STARTS...
2023 Kubota SVL97-2 Compact Track Loader (A63689)
2023 Kubota...
2019 KOMATSU WA320-8 WHEEL LOADER (A64279)
2019 KOMATSU...
2025 Swict 84in Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
