Live Vs independent PTO
   / Live Vs independent PTO #21
That's what I thought. But there are compact tractors with automatic independent PTO. If you raise the mower the PTO is automatically turned off. To resume mowing you'd have to reduce engine speed, lower the mower and then raise engine speed after the PTO automatically engages.
That seems to reduce the utility of the automatic PTO quite a bit. Which makes me wonder if on those machines the PTO engaging clutch engages gradually and is robust, in order to allow full engine speed engagement. (most of the tractors I have found with independent PTO have some sort of clutch, usually wet, that allows for gradual engagemnt.)
My tractor also has the automatic mode. I don't use it. It is a safety device primarily and I understand the reason for it but I simply never raise my spinning flail mower when anyone is around and I never leave the flail running when elevated off the ground when I dismount.
   / Live Vs independent PTO #22
I don't recall ever seeing a post on TBN about failure of a tractor related to starting an implement with an independent (generally electrohydraulic activation) PTO.
No, and that's not what I said. But I have seen posts about shearing pins on attachments on startup with this system. See for example: this one
   / Live Vs independent PTO #23
My 6530 has a live function in addition to Ind. There are no double clutch discs like in my 3000. The function is basically ind., but when in the live function you can depress the clutch and it will shut off the pto. I think I have 24 (wet) fluid cooled/"coddled" clutch discs in the system that act as shock absorbers, sequentially connecting.
It also has the switch controlled shut off for when you lift the implement at the end of a row (for example) and reinitiates it when you drop it. I also has a switch that operates the 3 pt. so you don't have to move the lever up and down each time you want to raise and lower; your arm rests on the control panel, thumb on one side, index finger on the other flip this way, flip that way implement up, implement down.
You pre set the lower limit of the 3 pt for setting depth of draft implements (and it does have the Ferguson system draft pressure selection lever also) with another arm height lever at the rear which you also use when you need to connect an implement and you can move the arms up or down. That's another nice feature. You have precision location capability with arm positioners with 10 holes and a drop pin to lock in place....no flopping all over. Then the ends of the arms have extenders for another 2" of fore aft adjustment and then the lift to move the arms up and down and finally the balancing leveler (like most tractors) where you can set the arms at different heights with respect to each other.
These niceties and more, including the Cummins B 3.3NA 4 cyl naturally aspired engine are the reasons I went with the badge.
   / Live Vs independent PTO #24
I had that issue with my 6' brush mower. (sheared pins when engaging at idle)
I put a slip clutch on my cutter to solve the problem.
My brush mower was the only place I notice the harsh start up.
7' finish mower, tiller, auger, Etc. it has been a non issue.
   / Live Vs independent PTO #25
I'd think a rotary cutter and a chipper would be the two most likely to be an issue. Both start fairly hard. Other tools I use don't have that much inertia and start pretty easy.
   / Live Vs independent PTO #26
TractorData.com - Power Take-Off
We have most types and prefer hydraulic independent. We always reduce RPM on engaging/disengaging.
http://www.tractorbynet.com/forums/.../177989-disengage-pto-before-idling-down.html
Yep. Me too. Both of my tractors have independent that is controlled by a linkage. I normally idle down and slowly engage. But occasionally I slowly engage with raised engine rpm. Either way it's possible to do it with minimal shock. Best part is not having to stop forward motion of the tractor to engage.
   / Live Vs independent PTO #27
My Kubota doesn't turn the PTO off if you leave the seat. But it sounds a loud alarm so you know you have done so.
I'll dismount with the PTO running to do something that has nothing to do with the rear of the tractor. But I'm very diligent about not going near the rear attachment. When I was a kid two neighbors got into a small round hay baler. One was completely baled and killed. One got his arm in it and the tractor died. Watched my Dad unassembled the baler and get him out. I don't go anywhere near a PTO attachment when it's running.
   / Live Vs independent PTO #28
Yes, shearing pins/bolts would be a bother but one easily remedied by installing a slip clutch.
   / Live Vs independent PTO #29
My Massey 1635 has an electrically engaged PTO but also has a "soft start" button that can be selected when using equipment like a brush cutter. Seems to work well and prevents the shearing of pins etc.
   / Live Vs independent PTO #30
Sounds like a desirable feature. Wish mine had that. I like the electrohydraulic activation but it would be nice to have a "soft start" option.
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
BOMAG SMOOTH DRUM ROLLER (A58214)
BOMAG SMOOTH DRUM...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
6" CONVEYOR BELT (A54757)
6" CONVEYOR BELT...
