Live Vs independent PTO
   / Live Vs independent PTO #11
Thanks for explaining, Vince.
But why would anyone want a PTO system that doesn't let you feather in when you engage the PTO? Seems like a design sure to break things.
   / Live Vs independent PTO #12
There is a bit of a lurch when an independent PTO engages but no more so than the lurch that a truck makes when engaging first gear from a stop. The engineers who designed the tractor and truck presumably took those "shock" loads into consideration when designing and building the machinery.
   / Live Vs independent PTO #14
Really? I've never seen a truck lurch when starting when operated by a competent driver. That's why gear-drive trucks have clutches.
How about the designers of the equipment that impose the loads? It's there that we see issues mentioned by members on this forum.
   / Live Vs independent PTO #15
I don't recall ever seeing a post on TBN about failure of a tractor related to starting an implement with an independent (generally electrohydraulic activation) PTO. If I have any concerns about the one on my tractor it is only for the electrohydraulic switching, not the strain on the tractor. I engage the PTO at roughly 300rpm above idle to avoid stalling. I sense a lurch but no worse than the lurch felt when a bush hog hits a 2" sapling. I'm pretty sure that we'd hear about failures of implements if electrohydraulic independent PTOs were causing damage.
   / Live Vs independent PTO #16
   / Live Vs independent PTO #17
You can ease the engagement of the PTO by lowering the engine RPM before flipping the switch/lever/control. Generally it's not necessary, but it won't hurt anything. I'm sure there's a certain amount of slip built into the system when it engages just based upon how smoothly they tend to engage.
   / Live Vs independent PTO #18
I've also owned tractors with both types and my current one with the independent is preferable to me. Mine has a rotary switch with an auto mode where the PTO will stop if you raise the hitch up to a certain height or push the clutch in, or manual mode where it stays on in those cases. In either mode you can turn it on/off with the push button switch on the steering column at any time. I almost always use it in manual mode. I don't like engaging at high rpms with the bushog on because of the mass to get moving but it's no problem with the finish mower, tiller or post hole digger. For the bushog I'll cut rpms back to around 1500-1800 before engaging.
You should throttle down before engaging independent PTO otherwise you will deliver big shock loads to both the implement and the PTO. .
That's what I thought. But there are compact tractors with automatic independent PTO. If you raise the mower the PTO is automatically turned off. To resume mowing you'd have to reduce engine speed, lower the mower and then raise engine speed after the PTO automatically engages.
That seems to reduce the utility of the automatic PTO quite a bit. Which makes me wonder if on those machines the PTO engaging clutch engages gradually and is robust, in order to allow full engine speed engagement. (most of the tractors I have found with independent PTO have some sort of clutch, usually wet, that allows for gradual engagemnt.)
   / Live Vs independent PTO #20
That seems to reduce the utility of the automatic PTO quite a bit. Which makes me wonder if on those machines the PTO engaging clutch engages gradually and is robust, in order to allow full engine speed engagement. (most of the tractors I have found with independent PTO have some sort of clutch, usually wet, that allows for gradual engagement.)
My tractor has the manual or automatic independent PTO.
In never use automatic (never found a use for it really). I use manual only and engage all my attachments at idle.
LOT: (5) Bolt Cutters (A59076)
LOT: (5) Bolt...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
2008 FORD F-350 SUPER DUTY (A58214)
2008 FORD F-350...
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
