one http to many this should work AOL Search
Grrrr see told you a rookie GenerLink.com - About GenerLink - The easy way to connect a home generator
If the grid is down, it will backfeed through the transformer and try to energize the grid. If the grid is on, the grid will force the generator to sync with it which can destroy the generator.What happens when someone "accidentally" plugs a running generator into the grid? I don't have or use a generator but just curious. Does the voltage backflow thru the power line transformer and then go upstream as a higher voltage? Seems like if it did the load would instantly stall the generator. Probably a stupid question?
Can't see how the utility recommends running a mess of extension cords instead of using a proper transfer switch.
