Little Concrete Wheel Weight Project
   / Little Concrete Wheel Weight Project #1
putt_putt_green
Western Central lower penisula MI
JD 3520
Ingredients
7 5/8 x 8 hex bolts
7 5/8 nuts
20 5/8 washers
6 1/2 washers (bored out to 5/8)
6 5/8 lock washers
1 small metal garbage can as for a form
Small piece of fence
3 bags of concrete
1 old metal broom handle
1 piece of galvanized pipe
6 5/8 collars
Took several piece of circular wood pieces and screwed them together (raised to clear the lug nuts).
Put 3 holes in the wood to match up with holes in the tractor rims.
Cut an old metal broom handle into 5 inch pieces.
Attached the bolts and washers to the wood pieces.
The extra bolt will be used for a removable handle.
http://i187.photobucket.com/albums/x10/todd_and_katy/WheelWeight/WheelWeight1.jpg
I then push the wood pieces tight in the trash can.
I then poured a little concrete in the the trash can.
I then added metal fence for reinforcement.
http://i187.photobucket.com/albums/x10/todd_and_katy/WheelWeight/WheelWeight2.jpg
Poured the rest of the concrete.
Put the handle (bolt) in the concrete.
Painted the wheel weight after cured.
Attached the bolts to the rims using collars.
http://i187.photobucket.com/albums/x10/todd_and_katy/WheelWeight/WheelWeight3.jpg
Slid the wheel weights on the bolts and tightened.
Unscrewed the handle from the nut/washer embedded in concrete.
Weight is about 85 pounds per wheel weight.
http://i187.photobucket.com/albums/x10/todd_and_katy/WheelWeight/WheelWeight4.jpg
http://i187.photobucket.com/albums/x10/todd_and_katy/WheelWeight/WheelWeight5.jpg
   / Little Concrete Wheel Weight Project #3
BlacknTan said:
Very ingenious!!
Absolutely!
This is the kind of thing that makes America great.
Ingenuity!
   / Little Concrete Wheel Weight Project #4
Nice ! All you need now are some chrome nut covers to accent that new yellow paint !
   / Little Concrete Wheel Weight Project #5
Nice job!
David from jax
   / Little Concrete Wheel Weight Project #6
What does JD want for wheel weights, and how much did yours cost? Good job.
I don't remember how much the John Deere wheel weights were, but I remember I thought they were expensive. I think it was around $100 per wheel.
My total cost, just guessing, is probably $13 for the collars, $9 for concrete, and $13 for bolts, washers and nuts. So probably about $17.50 per wheel. The rest of the ingredients were just hanging out waiting to be used.
Thanks for the complements everyone.
   / Little Concrete Wheel Weight Project #8
Thanks for posting this simple yet very effective idea!!! I didn't want my rear tires filled and so far was too cheap to buy wheel weights for my tractor, because they would set me back by about $120 or so. DIY is the way to go. You should paint a smiley face on there with green paint. That is what I'm going to do.:) I made my weight box too for about $20 following suggestions from TBN members.
   / Little Concrete Wheel Weight Project #9
Hope you torqued those lug bolts before the weights went on, cause you ain't gonna get to 'em easy now.
   / Little Concrete Wheel Weight Project #10
I don't see the valve stem, or is it hiding on the back side of the wheel for some reason.
50ft Fuel Line (A51573)
50ft Fuel Line...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53472)
2014 Doyle Dry...
Pintle Hitch (A51573)
2003 Pace American Trailer, VIN # 4FPW540373G068816 (A51572)
2003 Pace American...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
BROWN MPT-30 LOT NUMBER 67 (A53084)
BROWN MPT-30 LOT...
