Little Concrete Wheel Weight Project
   / Little Concrete Wheel Weight Project
Hope you torqued those lug bolts before the weights went on, cause you ain't gonna get to 'em easy now.
The lug nuts were tight before putting the wheel weights on. I park the tractor inside, so the bolts should never get rusty. The weights come off easy enough, so getting to the lug nuts is not a problem. I can reach both end of the hex bolts which are holding on the wheel weights.
I don't see the valve stem, or is it hiding on the back side of the wheel for some reason.
The valve stems are facing inside of the tractor (widens the stance of the tractor).
Not much weight, 85 pounds per weight for a total of 170 pounds. Looking back I probably could've made them a bit thicker, maybe another 10-15%.
PALLET OF MISC PARTS (A52708)
PALLET OF MISC...
POLY TOTE W/ WIRE CAGE & PALLET (A52708)
POLY TOTE W/ WIRE...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
