Little advice on holes?
   / Little advice on holes? #1
Raul-02
the armpit of the entire universe New Jersey
kioti DK4710 SE HST CAB
Post hole digging in mucky conditions that keep filling with slop.
The long sordid tale of drunkenness and cruelty:
Some years ago, we had a water table change. More rain than in all recorded history over a two-year period. It poured every single day for two years. I couldn't mow large parts of my yard for three more years after. Was having to pull my mower out of the slop sometimes two or three times every mow. Put a 1" X 100' rope down, get my truck in a dry spot and pull.
It's been rain bombs ever since. It does dry out, but, after winter, it takes a while.
I'm putting post holes in a newly bogged-up wet area. It'll dry out eventually. I do plan to subsoil the hell out of it off downhill.
Anyway, the problem
The hole is mucky I'm thinking I have two choices:
1) use the hand digger to clear the rocks then flood the hole with more water and just shove the post down into the soup ad then backfill with rocks.
2) Rent a trash pump.
One mucky hole I did this to, I was able to go get buckets of dry earth, dump that in, and sop up the water so the bigger could work. But this hole fills too fast.
Got any better ideas?
   / Little advice on holes? #2
Drive them in or do as they do in Ar when it's near solid rock,pile stones around post to hold it.
   / Little advice on holes? #4
Some years ago, we had a water table change. More rain than in all recorded history over a two-year period. It poured every single day for two yearsnot exaggerating here are you?. I couldn't mow large parts of my yard for three more years aftercontinued exaggeration?. Was having to pull my mower out of the slop sometimes two or three times every mow. Put a 1" X 100' rope down, get my truck in a dry spot and pull.
It's been rain bombswhat is that? ever since. It does dry out, but, after winter, it takes a while.
I'm putting post holes in a newly bogged-upwhat is that? wet area. It'll dry out eventually. I do plan to subsoil the hell out of itwhat does this mean? off downhillwhat does THIS mean?.
Anyway, the problem
1) use the hand digger to clear the rocks then flood the hole with more waterwhy? and just shove the post down into the soup ad then backfill with rocks.
2) Rent a trash pump.why?
One mucky hole I did this to, I was able to go get buckets of dry earth, dump that in, and sop up the water so the biggerHuh? could workdo you pay him?. But this hole fills too fast.
Got any better ideas?sure - plenty if I only knew wth you were talking about LOL.
Nope. That actually happened. It was unfrigginBelievable~!!
Newly bogged up: Wasn't a bog before is now
subsoil the hell: drop my subsoiler and drive all over the place.
Yes I pay the Bigger ooops Digger. I pay him with Gear oil.
" if I only knew wth you were talking about LOL" You never had a post hole that was filling with water collapsing the sidewalls and making your life miserable?
God bless, That's all I can say. Don't piss off the water spirits
   / Little advice on holes? #6
Mine just fill with water where I'm at. Usually the sides hold. I have had luck dropping the post in the water, back filling with dry concrete and tamping it in.
   / Little advice on holes? #7
so your ground is flooded but yet too solid to drive the post in without digging it but too soft for the wall to hold ? ... My buddy did holes in the sand and had the issue with side wall collapsing so he would stop the rotation before lifting the post hole digger and the side wall would stay intact, maybe give that a try...
   / Little advice on holes? #9
question: why now & not when it does eventually dry out like you say?
I didn't say that. I do not own a driver. Wish I did. Stopping the rotation ( after adding fry dirt) was how I lcleared the other hole, this one however seems to be in an underground river (sarcasm) It fills too fast for that trick.
2024 JOHN DEERE 4044M LOT NUMBER 65 (A53084)
2024 JOHN DEERE...
2023 AGT Topcat Stump Grinder (A51573)
2023 AGT Topcat...
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
12" x 16.5" Kubota RTV-X1140 Tires (A52377)
12" x 16.5" Kubota...
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
