Lithium battery for tilt trailer?
   / Lithium battery for tilt trailer? #1
NonTypicalCPA
SW Michigan
Kubota L3940
Anyone using a lithium battery on their tilt or dump trailer? How do they perform? I’m considering one for my recently purchased tilt trailer.
   / Lithium battery for tilt trailer? #2
I'm sure they would work great, providing you get the battery with a proper capacity, but they aren't very cheap yet.
   / Lithium battery for tilt trailer? #3
why bother...i use a standard interstate battery and i added a trickle charger plug so it stays plugged in. trailer is 4 years old...same battery. works every time. Li batteries are like 3x the cost. wont last any longer.
   / Lithium battery for tilt trailer? #4
LI batteries are like chrome tail pipes on your motorcycle. Look snazzy but provide no better service.
   / Lithium battery for tilt trailer? #6
They will last a good deal longer than a lead-acid battery, generally. But not really worth the trade-off at the current price point. They are usually considerably lighter for the same capacity also, but that's not something I worry about too much for a tractor or a trailer.
   / Lithium battery for tilt trailer? #7
Look in to the cold weather performance of Lithium batteries before making the plunge... particularly cold weather charging limitations.
   / Lithium battery for tilt trailer? #9
I’d buy a AGM battery and call it done. I’m sure a lithium battery ain’t cheap.
Agreed. AGM batteries tend to hold their charge longer when sitting idle, and have a wider range of operating temperatures on the low end.
I put a a group 27 Deep Cycle AGM battery in my dump trailer 5-1/2 years ago which is still doing well.
I put an Optima Yellow top AGM in my tractor when the sealed flooded lead-acid battery died 8 years ago. I was lucky to get 4 or 5 years out of the flooded lead acid batteries. The Optima is still going strong.
   / Lithium battery for tilt trailer? #10
I have an Odyssey AGM battery in my Kubota. 1200 cold crank amps. I don't even know if a LI battery is made to fit this application.
2005 John Deere 824J Articulated Wheel Loader (A49461)
2005 John Deere...
377780 (A48837)
377780 (A48837)
CATERPILLAR 12" BACKHOE BUCKET (A51242)
CATERPILLAR 12"...
2019 CATERPILLAR 930M WHEEL LOADER (A51242)
2019 CATERPILLAR...
2018 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2023 Komatsu WA320-8 Articulated Wheel Loader (A49461)
2023 Komatsu...
