Listing of non-JD/Frontier Implements for I-match
   / Listing of non-JD/Frontier Implements for I-match #11
Runner said:
"It's been my experience that anything with the "KingKutter" name works pretty well right off the truck."
Maybe you have a different model than mine, but neither my KK 6 foot rake, nor my KK carryall worked with the iMatch. I had to make an adapter.
Also, Houndsman, you might want to make a distinction in the listing as to whether things that are "compatible" are that way out of the box, or do they need an adapter kit. My Frontier RFM required an adapter kit as did my Frontier rotary cutter, even though both adapter kits were available from the factory.
You may want to consider listing by what is "compliant" and what is "compatible." I believe compatible would require "adaptation." "Compliant" would mean just that -- compliant.
JGY
   / Listing of non-JD/Frontier Implements for I-match #12
I have a Land Pride 50" tiller that fit right up to may I-Match. No modifacations
CF Hartman, got it. Thank you sir, I'll add it to the list.
JGY and Runner, how's about I note our FAQ List standards like this:
"* Compliant= fits the Imatch right off the truck/out of the box.
* Compatible= fits the Imatch w/ a specified, factory manufactured adapter (e.g. Bushing kit, extention kit)."
So, the task then is to ask the TBN body to tell us about their non-JD/Frontier Implements that worked in compliance or were compatible with the JD I-Match quickhitch.
Again, the purpose is for me to post it as a string under "JD FAQ" thread for JD references. When we get the I-match done, then we'll move onto the Speeco and other quick hitches.
v/r mark
   / Listing of non-JD/Frontier Implements for I-match #14
Runner, could you post a close up of the RFM adapter?
I have a 6' Woods, and use a Speeco floating top link, but it doesn't float enough....
I recall the Woods kit as being $100+, but have never actually seen one.
I'm wondering if it's something that I can rig up.
Thanks,
Jon
   / Listing of non-JD/Frontier Implements for I-match #15
I have a Bushog Squealer model 6' that works great right out of the box. I do use the floater attachment for the center link.
   / Listing of non-JD/Frontier Implements for I-match #16
Galway,
Here's the parts diagram from Woods for the iMatch adapter kit:
   / Listing of non-JD/Frontier Implements for I-match #17
I have a sitrex RH -4125 tiller that worked "right out of the box"
   / Listing of non-JD/Frontier Implements for I-match #18
As I recall, Woods makes a lot of the Frontier equipment for JD.
   / Listing of non-JD/Frontier Implements for I-match #19
My landpride rear blade fits the Imatch with out issue. I've found woods and LP fit the Imatch and only the lesser know brands or economy lines(king cutter etc) seem to have fittment issues.
Matt T.:D
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2014 Ram 1500 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 Crew...
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55788)
2021 Chevrolet...
2004 CATERPILLAR 420D IT BACKHOE (A51406)
2004 CATERPILLAR...
KENMORE 80 SERIES WASHING MACHINE (A54757)
KENMORE 80 SERIES...
