Listing of non-JD/Frontier Implements for I-match
   / Listing of non-JD/Frontier Implements for I-match #1
Houndsman
8000ft, Colorado
I am a dedicated I-match user. I was thinking that it would be beneficial for us if we could develop a list of implements that you'all have had success in using with a JD I-match----without modifications.
The endstate for this list would be for me to put it in the JD "Sticky" notepage that Muhammad set up for us.
What other-brand implements have yall had success with when using an I-match?
v/r mark
   / Listing of non-JD/Frontier Implements for I-match #2
The Woods GB65 Box Bade I got worked the minute I took it off the truck....
   / Listing of non-JD/Frontier Implements for I-match #3
I have Buhler ( Farm King and Allied) box blade and blower. They are both a perfect fit. As I understand it they have their own quick hitch made to industry standard specs and any implements spec'd as quick hitch compliant should fit the I-match.
   / Listing of non-JD/Frontier Implements for I-match #4
Woods rear blade worked on my iMatch with no problems...:)
   / Listing of non-JD/Frontier Implements for I-match #5
It's been my experience that anything with the "KingKutter" name works pretty well right off the truck.
6" Rear blade - Check
6'" Rake - Check
Middle buster...it fits, but doesn't stand up. You need to get off the tractor.
   / Listing of non-JD/Frontier Implements for I-match #6
62" Meteor snowblower fits great, but needs pto extention.
   / Listing of non-JD/Frontier Implements for I-match #7
"It's been my experience that anything with the "KingKutter" name works pretty well right off the truck."
Maybe you have a different model than mine, but neither my KK 6 foot rake, nor my KK carryall worked with the iMatch. I had to make an adapter.
Also, Houndsman, you might want to make a distinction in the listing as to whether things that are "compatible" are that way out of the box, or do they need an adapter kit. My Frontier RFM required an adapter kit as did my Frontier rotary cutter, even though both adapter kits were available from the factory.
I'm learning by the minute......special thanks to yall. I've started the list, trying to stay as simple as possilble. The categories are: "Item""Notes/Comments""TBN contributor".
As the thread contiues to develop, I was beginning to think that based on some of yalll's answers, we might be able to make some assumptions. What comes to mind for me based on what I am learning from your experience(s) is:
Is it too early to make a general assumption about Woods and Buhler implements? I do acknowledge that there are some JD/Frontier implements that are not Imatch compatible.
To the rest of TBN, what other-brand implements have yall had success with when using an I-match?
v/r mark
Runner, sweet system. Can we get the "Runner Adaptation" photos and anything else you can share w/ us? Might as well, while we're at it.
v/r mark
   / Listing of non-JD/Frontier Implements for I-match #10
Here you go. Also, here is a pic of the Frontier RFM. The adapter kit consists of the two black bent bars that hold the upper link in position (hard to see) and the chains that replace the normal rear frame members. Incidentally, this adapter kit is also required for the Woods version of this mower, the RD7200.
Hutchinson 10x71 Transport Auger (A50775)
Hutchinson 10x71...
2003 Pierce Spartan Pumper Fire Truck (A55852)
2003 Pierce...
(10) 2" X 6" X 24" TUBING (A54756)
(10) 2" X 6" X 24"...
2021 TAKEUCHI TB240 EXCAVATOR (A52705)
2021 TAKEUCHI...
(3) PALLETS OF MISC JOHN DEERE PLANTER PARTS (A54756)
(3) PALLETS OF...
Unverferth Gravity Wagon (A50775)
Unverferth Gravity...
