Linear actuator for power SSQA?
   / Linear actuator for power SSQA? #91
I wonder if this will work as well if the tractor and attachment set outside for a few weeks. I find that if mine gets muddy and sets out for a while, it will get a little rusty, and I have to get a hammer to open or close the latches.
Mine sleeps in the barn, so I can't answer that. Also, there are grease zerks on the sleeves for the locking pins on my Kubota. I hit them whenever I grease everything else. Never had any rust or stickiness issues.
   / Linear actuator for power SSQA? #93
And when you think about how many actual skid steers spend their entire life outdoors, it seems off to have to hammer on them every few weeks
   / Linear actuator for power SSQA? #94
You are right on the money. I've started to build a hydraulic quick attach using this diverter:
12 VDC 13.2 GPM SAE 8 SOLENOID DOUBLE SELECTOR VALVE
and this cylinder:
1X8X0.5 DA HYD CYL
I am indebted to the OP and these linear actuator threads for making me start thinking about automatic quick attach possibilities.
Post a thread when you get it going.
Now you got me all excited..... :)
I was a bit low on my cost estimate though. You'll probably have another $50 in hoses, fittings, electrical.
And a pressure relief valve.
   / Linear actuator for power SSQA? #96
I'd use a cylinder that can stand the tractor pressure without the use of a relief valve.
Will be interesting to see what he comes up with.
I'm all about your setup. I just can't past the question of what happens when the latches are jammed or some unseen obstacle prevents them from their intended travel?? Does the actuator just sit there burning on the motor until the operator shuts off the switch??
This is why manual latches have spring loaded pins. If the pin cannot completely latch, the spring will continue to push until it does latch.
As I mentioned when I posted on my v2 build... The bar was a bit to long & the 15@ rated linear actuator ended up pushing both brackets into the loader arms. The 10@ fuse promptly popped. I was watching for this possibility, so it popped pretty quick, before I could throw the switch. A circuit breaker might be a bit handier, but I'm happy with the functionality & safety of this setup.
I wouldn't want a full pressure hydraulic cylinder trying to separate my loader arms, or more importantly trying to crank down on the levers & pins. A thousand pounds or 2 of force there is apt to break something, especially if only 1 pin catches or what not. In my current case the weak link is that 10@ fuse, nice & easy to replace. Without a pressure relief valve in there on a hydraulic cylinder it might be the pins, a bolt or the lever. Probably not the loader arms or cross bracing, but who knows (especially if the stroke + brackets for the cylinder are wider than the inside of the loader arms).
   / Linear actuator for power SSQA? #98
If the stroke is set up correctly the latch springs will protect everything when closing. The end of the cylinder stroke will protect everything when opening. Should be very easy to get that all worked out. No different than your issues in regards to stroke.
So your limiter is your fuse. I guess that will work fine as long as you are always very aware when opening/closing. I might change attachments 3 or 4 times a day. I'm wayyy too forgetful. I'd hafta carry a pocket full of fuses. :)
You only need a fuse when it jams. All linear actuators I've seen have internal limit switches. They shut off automatically at max extension & retraction (fancier costlier ones have adjustable limit switches). I'm relying on those limit switches for normal operation. If something jams & forces the actuator to work near maximum power (like when my brackets were to long & hit both loader arms) the fuse pops preventing any damage to the SSQA mechanism, wiring or actuator.
Also my Kubota has 4 slots for spare fuses in the fuse box & comes stocked with fuses from the factory. ;-)
   / Linear actuator for power SSQA? #100
Hey, I'm with ya on this. I think you'll get along with it fine. And it's a great build.
For my needs I think I'd prefer hydraulic.
If I didn't have 3rd function on the FEL the equation would change.
Good build. Keep us posted on how it all works out for ya. :thumbsup:
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2018 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52707)
2018 CATERPILLAR...
2015 International DuraStar 4300 26ft. Box Truck (A55852)
2015 International...
UNUSED FUTURE CAT 305 EXCAVATOR RIPPER (A57193)
UNUSED FUTURE CAT...
Caterpillar 259D (A53317)
Caterpillar 259D...
2009 Ford E-450 Super Duty Ambulance (A55852)
2009 Ford E-450...
