lincoln sa200 continental engine ???????
   / lincoln sa200 continental engine ??????? #11
This might help, specs right from Lincoln.
Thanks SA!!
36 hp at 1450 !! quite a bit more than I anticipated !
might be around 40 hp at 1800, should be good for about 18kw, provided I can get it running to its full potential without breaking the bank !!
Thanks again!!
Scott
   / lincoln sa200 continental engine ??????? #13
The next stuck engine I work on will either have a good dunk in molasses, or the bad cylinders filled up. I wouldn't be surprised if that outdoes every form of penetrating oil out there.
there are many videos online demonstrating how well it works.
Well I pulled the head off it yesterday. all 4 bores look to be in good shape. 3 & 7/16 bore so it does seem to be a f162. I am able to spin it over by hand, it turns smooth though about 120 degrees , then gets notchy.I'm hoping it in the geartrain and not a spun bearing or ?????
2014 Toro Z-Master 3000 Series 52in Zero Turn Commercial Mower (A56857)
2014 Toro Z-Master...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
Online Buyers Premium (A55272)
Online Buyers...
Sellick 560 Forklift (A57148)
Sellick 560...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
