LINAK Electric Chute Actuator
   / LINAK Electric Chute Actuator #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
Hi All.
I have a Kubota Front mount Snowblower model B2782B which has an Electric Chute Actuator on it.
It is a LINAK Actuator Type 123000-1130122X, Item 120210-01 I think it is a Model LA12, but not sure. ( I have attached a pic of the sticker on the actuator).
It's getting power, and I can hear it "trying", but it doesn't move at all.
I also thought I saw water coming out of it.
Is there any possibility of troubleshooting and repair?
Or should I just replace it? Any idea where I can purchase a replacement?
Thanks for the help.
   / LINAK Electric Chute Actuator #2
Since it's broke, why not just take it apart and see what's inside? Maybe it just needs to be cleaned out.
I would love to have something like that come across my bench...
I may just try to open it up. I am curious as to what's inside anyway.
I have sent off an email to LINAK to see if they can offer any trouble shooting tips.
   / LINAK Electric Chute Actuator #4
I forget where I bought mine. Probably Amazon or Ebay. Very common and fairly cheap IIRC.
   / LINAK Electric Chute Actuator #5
chim - I can see that you can angle the tip. Can you also rotate the entire chute? What is all that lower black bar & stuff???
   / LINAK Electric Chute Actuator #6
Yes it rotates from the cab. I made a pendant with two small rocker switches in it (UP/DOWN and RIGHT/LEFT). There's a relay box on the back of the cab, so the switches are pilot duty. That lower black bar is a pipe and the end towards the tractor has a small 12V geared motor adapted to it. A cable wraps around the chute and the ends of the cable are wound onto the pipe in opposite directions. A clip hold the cable on the chute so it doesn't slip. When the motor turns the pipe it winds / unwinds the cable and rotates the chute.
Everything worked pretty well, but the blower was sold along with the L3200 about a year ago. The blower was fun for a while. The power-angle 8' plow on the L4240 is far more useful for me. At our place we have plenty of area to push snow away. I plow parking lots at our church and the blower didn't work well there. Too far to blow the snow in one shot, and every time it gets re-blown it's much harder to throw.
   / LINAK Electric Chute Actuator #7
Chim - spot on!!! I have a mile long gravel driveway, mailbox area and large yard. Three and a half to four hours using the 3-point blower was never my idea of fun. Now it's my big Rhino rear blade on the M6040 that clears snow. Going in a forward direction is so much easier on the neck/shoulders.
   / LINAK Electric Chute Actuator #8
I'll 2nd that. Very cheap & very common. Just measure the closed length & how far it needs to extend along with the bolt hole sizes at the ends.
There are 100-200lbs ones that are relatively slow under $50. The next step up is around $100 for more power & speed. They make identical looking ones that trade speed for power by just using shorter or taller gearing internally.
Generally plastic gears on the inside on the cheap ones & even not so cheap ones. Probably what broke.
Thanks to everyone for their insights.
I am in search of a place to grt the actuator repaired.
A brand new matching replacement actuator is close to $700. I can buy a complete Actuator "Kit" (B2516A) fro $627 plus tax from my local dealer.
I think if I can fins a place to repair it, that would be a much cheaper option.
But I can't locate a repair center for LINAK yet.
I could open it up myslef and take a look, but I don't have access to parts anyway, so no sense for me to try to repair it myself.
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2016 Ford Expedition SUV (A55853)
2016 Ford...
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
Native American Wooden Head Statue (A55853)
Native American...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
