Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #1
SinopecLubes
houston, texas
john Deere 2100
(Walmart) PRICE: $17.52 per 5 gallon bucket https://www.walmart.com/ip/AW-68-Hydraulic-Oil-Fluid-ISO-VG-68-SAE-20-5-Gallon-Pail/720809462
Sinopec Anti-wear Hydraulic Oil ISO VG 68 is a premium heavy weight paraffinic based hydraulic oil, ideal for industrial applications or for the hydraulic systems in warm weather regions. It is a rust and oxidation (R&O)-inhibited oil with the added benefit of an anti-wear additive package for protection. Approved for industrial applications requiring an ISO VG 68. Certifications: ISO 11158-HM, DIN 51524 Part 2, Cincinnati P69, Easton Vickers M-2950-S and I-286-S, Parker-Denision HF-2
(AW) ISO VG 68 - SAE 20
Meets major pump manufacturer requirements including Eaton-Vickers 35VQ25A for M-2950-S, I-286-S, Parker Hannifin Denison HF0/HF2/T6H20C, Bosch Rexroth Racine Model S
ASTM D6158 HM
DIN 51524-2
ISO 11158 L-HM
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #2
There is no national standard for hydraulic oil. The specific vehicle manufacture sets the standard so use what they say you should...unless your putting this in a 1980s log splitter
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #3
And then using it in the tropics.
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #4
Says $39.98 when I click on the link.
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #5
I try to keep away from Chinese products and this is one of them..
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #6
Thanks - but no thanks. I will use a product specifically listed for my tractor. Too much at risk otherwise. When the tractor goes ****-up on the cheaper product - the fact that I saved a few bucks will be of little comfort.
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #7
So Sinopeclubes, are you a new vendor here?
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #9
Chinese oil company, he has posted infrequently since 2015.
5 posts in three years.. I should have looked at that..
1995 Ford L8000 Grain Truck GARAGE KEPT (A55301)
1995 Ford L8000...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2004 Ford E-350 Passenger Van (A51692)
2004 Ford E-350...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
