Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #1
SinopecLubes
houston, texas
john Deere 2100
(Walmart) PRICE: $17.52 per 5 gallon bucket https://www.walmart.com/ip/AW-68-Hydraulic-Oil-Fluid-ISO-VG-68-SAE-20-5-Gallon-Pail/720809462
Sinopec Anti-wear Hydraulic Oil ISO VG 68 is a premium heavy weight paraffinic based hydraulic oil, ideal for industrial applications or for the hydraulic systems in warm weather regions. It is a rust and oxidation (R&O)-inhibited oil with the added benefit of an anti-wear additive package for protection. Approved for industrial applications requiring an ISO VG 68. Certifications: ISO 11158-HM, DIN 51524 Part 2, Cincinnati P69, Easton Vickers M-2950-S and I-286-S, Parker-Denision HF-2
(AW) ISO VG 68 - SAE 20
Meets major pump manufacturer requirements including Eaton-Vickers 35VQ25A for M-2950-S, I-286-S, Parker Hannifin Denison HF0/HF2/T6H20C, Bosch Rexroth Racine Model S
ASTM D6158 HM
DIN 51524-2
ISO 11158 L-HM
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #2
There is no national standard for hydraulic oil. The specific vehicle manufacture sets the standard so use what they say you should...unless your putting this in a 1980s log splitter
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #3
And then using it in the tropics.
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #4
Says $39.98 when I click on the link.
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #5
I try to keep away from Chinese products and this is one of them..
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #6
Thanks - but no thanks. I will use a product specifically listed for my tractor. Too much at risk otherwise. When the tractor goes ****-up on the cheaper product - the fact that I saved a few bucks will be of little comfort.
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #7
So Sinopeclubes, are you a new vendor here?
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #9
Chinese oil company, he has posted infrequently since 2015.
5 posts in three years.. I should have looked at that..
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A55302)
John Deere 5090E...
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2007 FORD F250 XL SUPER DUTY TRUCK (A54756)
2007 FORD F250 XL...
2015 Ford Taurus SE Sedan (A54815)
2015 Ford Taurus...
