Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #1
SinopecLubes
houston, texas
john Deere 2100
(Walmart) PRICE: $17.52 per 5 gallon bucket https://www.walmart.com/ip/AW-68-Hydraulic-Oil-Fluid-ISO-VG-68-SAE-20-5-Gallon-Pail/720809462
Sinopec Anti-wear Hydraulic Oil ISO VG 68 is a premium heavy weight paraffinic based hydraulic oil, ideal for industrial applications or for the hydraulic systems in warm weather regions. It is a rust and oxidation (R&O)-inhibited oil with the added benefit of an anti-wear additive package for protection. Approved for industrial applications requiring an ISO VG 68. Certifications: ISO 11158-HM, DIN 51524 Part 2, Cincinnati P69, Easton Vickers M-2950-S and I-286-S, Parker-Denision HF-2
(AW) ISO VG 68 - SAE 20
Meets major pump manufacturer requirements including Eaton-Vickers 35VQ25A for M-2950-S, I-286-S, Parker Hannifin Denison HF0/HF2/T6H20C, Bosch Rexroth Racine Model S
ASTM D6158 HM
DIN 51524-2
ISO 11158 L-HM
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #2
There is no national standard for hydraulic oil. The specific vehicle manufacture sets the standard so use what they say you should...unless your putting this in a 1980s log splitter
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #3
And then using it in the tropics.
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #4
Says $39.98 when I click on the link.
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #5
I try to keep away from Chinese products and this is one of them..
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #6
Thanks - but no thanks. I will use a product specifically listed for my tractor. Too much at risk otherwise. When the tractor goes ****-up on the cheaper product - the fact that I saved a few bucks will be of little comfort.
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #7
So Sinopeclubes, are you a new vendor here?
   / Limited Supply | 5Gal Hyd Fluid PRICE: $17.52 | Walmart #9
Chinese oil company, he has posted infrequently since 2015.
5 posts in three years.. I should have looked at that..
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2016 John Deere 755K Crawler Loader (A47477)
2016 John Deere...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2015 CATERPILLAR 930K WHEEL LOADER (A51406)
2015 CATERPILLAR...
1992 Peterbilt 377 Sleeper Cab (A55301)
1992 Peterbilt 377...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
