Lime Application
/ Lime Application #1
DaRube
Loudoun County, VA
Kubota B7500HSD
I had my soil tested. The results were that I have lime applied twice, 50lbs per 1000 sq ft (or 1 ton / per acre) .... on two separate occasions at least a month apart. I want to have 3 acres done, so it would come to 3 tons each application. I actually have 3 more acres of grass (which tested the same), but they are located further from the house, so I was gonna let them be.
I have started calling vendors, but the first two have told me that they really only do 10 to 15 ton loads. Even if I was to have my entire property done, I would still only use half of what they need to deliver.
If I was to skip the waiting between applications, tho, and have them do the full 100 lbs per 1000 all at once, I would be able to use a truckload.
It isn't about the money for me, as going to the store, buying 50 lb bags of lime, and renting a spreader ... would certainly cost alot more. Not to mention the time and hassle involved.
My question is about the chemistry. What would be the impact of having one 100 lb application rather than two 50 lb applications?
Also, is this a good time of year (Northern Virginia) for me to have this done?
/ Lime Application #2
Wouldn't matter at all. Do it all at once if it's cheaper. When I do hayfields I do them all at one time in the fall and then till it in and plant in the spring.
/ Lime Application #4
Lay it on,no such thing as too much Lime in my book.This will "sweeten" the soil and require less fertilizer.It will take a couple of years to really see the results....
/ Lime Application #5
Dump it all on!
I have been there before, and will again visit the lime in a few short minutes on acreage just cleared. This is the third time these past few weeks.
If I had done it all at once, I could sit back and enjoy today.
Now I am fighting - logistics, the weather and my aching back...
Good Luck.
Hope the rains come!
-Mike Z.
/ Lime Application #6
How is lime sold? Is it by the ton or cubic yard or ??? And, roughly, how much does lime sell for, per measure, in the quantities you are talking about?
Kent
/ Lime Application #7
If you buy it bulk it will be by the ton. As far as price it all depends on where you are. Call your local farm co-op to get a price.
2015 FREIGHLTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2015 FREIGHLTLINER...
2018 HARPER ATM 72LC MOWER (A66091)
2018 HARPER ATM...
2006 GMC Savana 3500 Box Truck (A61573)
2006 GMC Savana...
2024 SILVERBACK 53CH3A TRI/A CAR TRAILER (A67148)
2024 SILVERBACK...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
2005 International 5900i T/A Gardner Denver Kill Truck (A64194)
2005 International...
