like father..like son ?
/ like father..like son ? #1
D7E
manitoba
Versatile 895 Versatile 876 Ford TW20 Ford TW5 MF 3505 FWA MF 390 FWA Ford 7600 Fiat 766 FWA JD 2030 MF 165 MF 35 Fordson major x 3 CAT 416 b Backhoe Case 580 b backhoe MF
My wife took this pic at the heat of combining ,We had done 12 days of 5am to 12pm ...**** and they say look at the mother ..This is scary ?
/ like father..like son ? #2
Funny how you cross your arms and even your legs are in almost the same positions. I've never been able to sleep in a sitting postion, but you guys sure look like your all wore out.
Eddie
/ like father..like son ? #4
I noticed you have the wine glass and the remote too!
/ like father..like son ? #5
I'll be flying back to Iowa this Saturday (for three weeks) to start basically the same thing. Dad had a late,wet spring and the soybeans still aren't quite really yet. After beans, then hopefully the corn will be down below 17-16.5% moisture content, so the drying cost won't be too much. He has one farm 10 miles away and that is when we see those 5am -midnight type days(but only 4 to 5 days).
Well it's 11pm on thursday and we finnished 1 hour ago ,I have a 12 pack and a pack of smokes and i aint getting up till lunch time tomorrow ,Almost a divorce every year but my boy will be happy to see me in daylight ,We started on august 10th till 4th october 3 trucks are still loaded and 3 tractors and 1 combine are still scattered around the county and thunder storms forecast for the next 3 days...perfect ?
We finnished with 300 acres of RR beans "ROSCO" and we had 17 inches of rain in june july but amazingly the beans averaged 45 bushells ,Very short this year and higher than average losses ,Moisture was 14.6 in morning and 9 % in afternoon and getting up to 15 all night . (Using a flex head)Oats averaged over 100 bushells but canola bareley did 20 bushells but we got 300 acres of beautiful alfalfa into small square bales all tarped and done ,Now starts the washing ,Fixing and putting stuff to bed for winter ,About 900 acres left to chisel plough but that should only take 2 days with 2 40 footers .
Then break out the chainsaws ,Service the CAT D7 and wait for it to feeze and it all starts again ?
..Do i sound older than 31..?...I'm the dirty one "the senior gets to finnish first and grab the wine bottle and remote" as he says "Go home ,Get your own" ?
Egon said:
What shape is the grain truck driver in??:D
..DONT even go there...My wife and my mother drive tandems with pups without major incident ...AMAZING...They don't need no encouragement.
/ like father..like son ? #10
D7E, My dad says the beans look as good as they did last year, which the yields were 59.5 bu/acre on 38" rows(old equipment). I seen bean moisture go from 12.5 to 9.5 in a hot, windy day. I haven't seen your numbers before. Around Iowa, we usually can't start combining until 9:30-10:00 am on beans, but that gives you time in the mornings to take the loads you combined (the night before) to the grain elevator. The latest I think I have combined beans was 11:30 PM, moisture starts to set in and the stems get tough and you can hear it in the combine. (usually stop 10:30PM). Dad stops at 7-8 PM, but he gets up at 4-4:30 am to feed cattle. I'm the haul guy until 7-8 PM, then I combine until it gets tough/ or a breakdown, then fill the combine with fuel each night and put it in the shed, then get the tractor and put the 2-4 wagons loads in the shed for the night. I'm kinda second-shift you could say. Dad greases the combine each afternoon before daylight goes away. On beans, as the haul guy, I usually have some "dead time", were I work on other projects between loads. Wash tractor windows, weld sometime that is broke, repack wheel bearings on forage wagons, etc.
We're lucky, the grain elevator is only 2 miles away. I am told my great-granddad bought coal there for their stove years ago because that's were the railroad stopped. They chewwed tobacoo and talked about farming(that was the local hangout in the wintertime).​
You definitely have a rougher harvest than we do, I guess you desire a beer or two.:)
I should've said that these are RR beans seeded in 7 inch rows with air seeder and due to a wet summer and very split germination some were dessicated with reglone ,You may not believe it but the second day combining the moisture changed that much between 10am and 5pm ,because in the morning they go in a dryer bin and in the afternoon they go in 10'000 bushell flat bottoms . What is dead time ...Ha..Ha with 2 combines i keep 2 tandems and a single axle moving ,6 miles to elevator,When doing oats the one tandem pulls a 800 bushel pup trailer and still sometimes i wait for a truck
If the moisture stays below about 14.8 we go till early hours and they do rumble but we have rotaries they are faster than conventionals but start to rumble if the sun goes behind a cloud ,You get used to it .
Egon said:
I knew it was the better half driving the grain trucks.:D :D :D
The guys love it in the elevator when a 25 year old woman with a 6 year old co-driver swings in with a Louisville 9000 with a 350 cummins and a 55 year old gray haired lady in a 22ft GMC brigadier with a 300 detroit ,Some times the ford is pulling a 17ft pup too-1550 bushells .
/ like father..like son ? #13
Back some years a friend of mine used to haul grain to the elevator!:D
He was 8 years old, had to stand behind the steering wheel and drove in low gear.
This would never happen today but in yesterday things were slower and quieter.:D :D :D
Egon ...youre one of the "old school" we've seen and done things that most would call the cops for ..."Dad says" and you do it or your in the service ?
/ like father..like son ? #15
Back when my FIL was still alive, when we were cutting hay, we would let my two sons drive the truck (an old chev, not sure of size, but it had a flat bed on it and was used to haul everything, with sides on it) while picking up the square bales. They wouldn't get to drive to the barn, but just in the open fields, usually sitting on a box or something with the truck in low gear, low range. they had to steer to get close to the bales and they loved to do it. They still talk about it today when we get together for a family event. I think about it everytime I hear that country song about "when daddy let me drive". And now I listen to Kenny Chesney sing "Blink", and think back again.
(Grandpa, Retired, Five kids, Youngest will be forty this year, 12 Grandchildren, and don't want to think of the next blink).
/ like father..like son ? #16
One more of the same kind.
A friend came by the other day, took this pic, and left. It was sent to me as an E-mali the next day.
Sweet?
Adams 5 T Fertilizer Spreader (A63689)
Adams 5 T...
2005 BIG TEX 16 T/A UTILITY TRAILER (A65643)
2005 BIG TEX 16...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
Skid Steer Hitch Plate (A65640)
Skid Steer Hitch...
