Lights & Horn Out. . .AGAIN!
   / Lights & Horn Out. . .AGAIN!
200 hrs, not a single problem with my 2012 R3039H. Horn and lights work fine.
Congratulations on the good service from your tractor. Other than the light problem, I've really enjoyed my tractor. I especially like the detachable bucket. As for the lights, I have a good dealer (Goss Equipment Co., Jasper, GA) and have confidence they will eventually find and fix the problem.
   / Lights & Horn Out. . .AGAIN! #22
Hopefully it will be an easy fix. I'm sure it's going to be something simple, just a matter of tracking it down. Hope they get you back in the seat quickly!
   / Lights & Horn Out. . .AGAIN! #23
My 4041 blew the fuse also , would love to know why. It only has 3hrs on it
   / Lights & Horn Out. . .AGAIN! #24
I know some of you are preaching fire & brimstone by adding a 1-sized-up fuse. But I checked & couldn't find a damaged or exposed wire anywhere that would cause the issue. Upgrading the fuse fixed mine. Perhaps they just didn't account for the proper amperage draw for all the lights. The dash lights, headlights, seat switch, (and horn maybe) are all drawing from it.
   / Lights & Horn Out. . .AGAIN! #25
Again what did the fuse look like?
   / Lights & Horn Out. . .AGAIN! #27
Here are some pictures of good and normally blown fuses, and some failed fuses that are open but failed from vibration, not overcurrent.
and a violently blown fuses due to an extreme overcurrent scenario.
   / Lights & Horn Out. . .AGAIN! #28
From memory, I'm thinking they looked like they were split in the middle, like the "open" one pictured.
   / Lights & Horn Out. . .AGAIN! #29
So no big black spot and total disintegration then? So then just a normal slight overcurrent situation.
   / Lights & Horn Out. . .AGAIN! #30
I believe so. Not like it was melted down or anything. Nothing that, at the time, made me think there was a series problem that couldn't be remedied by a larger fuse.
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
JET Vertical Milling Machine (A47477)
JET Vertical...
New/Unused Grapple for CFG Mini Excavator (A54865)
New/Unused Grapple...
2007 Oshkosh S-Series TMMB 11 Yard Front Discharge Concrete Mixer Truck w/ Tag Axle (A55788)
2007 Oshkosh...
