Lights for ROP?
/ Lights for ROP? #1
ssmith general
St. Clair County, Alabama
Kubota L4400
I have seen a bracket that fits on the ROP to install front and back lights. When I google it, I dont get anything.
A. Is there a product made for the ROP?
B. Did anyone make their own?
TIA
/ Lights for ROP? #2
A. Yes there is. Kubota sells it as an option, inlcude light and bracket. Check at your dealer.
B. I made my own bracket.
Philip
/ Lights for ROP? #4
I built my own using old bed frame and couple square clamps. It's easier then you think.
/ Lights for ROP? #7
I built my own brackets.
From my earlier post titled "Worklight Mounting on ROP"
I wanted to mount some worklights on my ROP and with all the posts about welding or drilling the ROP will void its certification, I designed a clamp on mount. The ROP on my BX2660 measures 1-1/2" x 3"
I searched a short time for a small 3 inch inside measurement shackle bolt but could not find a perfect match.
No problem, I'll just make one. Took some 3/8 steel rod, bent it in the shape I needed and threaded it. I then cut some 3/16 plate to 3 inches by 6 inches and drilled 3 holes. Two holes for the shackle bolt and one for the worklight mounting bolt.
$20 for the light at TSC and I already had the scrap metal.
/ Lights for ROP? #10
That looks really good.
/ Lights for ROP? #11
I made my own for my front and rear lights as well as my revolving light. It's a piece of 1 1/2" x 1 1/2" x 1/8" tubing with a piece of flatbar welded to each end drilled to match up witht the existing canopy holes in the rop....Mike
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
Sand Blast Pot (A65579)
Sand Blast Pot...
Mini Universal Grapple (A65640)
Mini Universal...
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
Zenith Pallet Jack Truck (A66408)
Zenith Pallet Jack...
