Lights for ROP?
/ Lights for ROP? #1
ssmith general
St. Clair County, Alabama
Kubota L4400
I have seen a bracket that fits on the ROP to install front and back lights. When I google it, I dont get anything.
A. Is there a product made for the ROP?
B. Did anyone make their own?
TIA
/ Lights for ROP? #2
A. Yes there is. Kubota sells it as an option, inlcude light and bracket. Check at your dealer.
B. I made my own bracket.
Philip
/ Lights for ROP? #4
I built my own using old bed frame and couple square clamps. It's easier then you think.
/ Lights for ROP? #7
I built my own brackets.
From my earlier post titled "Worklight Mounting on ROP"
I wanted to mount some worklights on my ROP and with all the posts about welding or drilling the ROP will void its certification, I designed a clamp on mount. The ROP on my BX2660 measures 1-1/2" x 3"
I searched a short time for a small 3 inch inside measurement shackle bolt but could not find a perfect match.
No problem, I'll just make one. Took some 3/8 steel rod, bent it in the shape I needed and threaded it. I then cut some 3/16 plate to 3 inches by 6 inches and drilled 3 holes. Two holes for the shackle bolt and one for the worklight mounting bolt.
$20 for the light at TSC and I already had the scrap metal.
/ Lights for ROP? #10
That looks really good.
/ Lights for ROP? #11
I made my own for my front and rear lights as well as my revolving light. It's a piece of 1 1/2" x 1 1/2" x 1/8" tubing with a piece of flatbar welded to each end drilled to match up witht the existing canopy holes in the rop....Mike
2016 JOHN DEERE 7210R TRACTOR (A65054)
2016 JOHN DEERE...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
90in. Work Bench (A65640)
90in. Work Bench...
SKIDED FUEL TANK (A65643)
SKIDED FUEL TANK...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
2016 Ford Transit 350 Enclosed Service Van (A64556)
2016 Ford Transit...
