Light weight 3 point offset mower
   / Light weight 3 point offset mower
Man oh man, there is no way I'm going to do anything that will attract hogs! The feral hog problem has gotten really bad here in southeast Texas. Less than a mile away across the creek that runs along the back border of this property is a large cultivated field that is usually planted in corn. I'm sure it has hogs in it when the corn is growing.
I planted Bahai grass around one of my other ponds out in the woods years ago. It got all covered over and a pretty green cover. Then one weekend I went out there and couldn't even drive my tractor over all the deep furrows the hogs had left behind. I had to back the box blade into the area and push dirt around just to be able to drive over for the final re-leveling.
   / Light weight 3 point offset mower #22
It would be a good excuse/reason for me to buy a ditch bank, 3pt hitch mounted rotary mower, Woods or Bush Hog, come to mind. Probably the hydraulic drive $$$$
Problem with the ditchbank rotary cutters is they require more tractor than I have.
   / Light weight 3 point offset mower #24
The EA sickle bar I linked to on p.2 requires much less tractor and will swivel while cutting 90^ up and 45^ down. It requires much less hp & weight than the OP's tractor. Note that it can be ordered with Tee'd lines to connect/use as would a diverter for a grapple lid. (vs add hydraulics for the tilt :thumbsup:)
The best info, is in the half (2nd) of this video that many might not stick around for. IMO it's a dandy "Light weight 3 point offset mower" .. , for way < than $4k or I wouldn't bring it up again. (just trying to help, honest)
5 Foot Sickle Bar Mower For Subcompact Tractors - YouTube
That is the sickle bar mower I've been considering, even before posting here (that or possibly the 6 or 7 foot). I have rear remotes so it will be simple. I'm just inquiring about other options but so far that seems to be the best.
   / Light weight 3 point offset mower #27
Sickle bars are also often sold used if you want to look around. I see them commonly for a song. Big hay operations have all moved to disc mowers, so there's a lot of used sickle bars out there.
   / Light weight 3 point offset mower #28
If your going to have a pond dug up it may be better to just have a 5 degree slope
put in on all three sides so you can use a lawn mower.
You could just invest in 2 or three trailer loads of red granite rip rap to hold the edges in place
for the cost of a new sickle bar mower. The rip rap would be at the bottom of the 5 percent slope
and you will have firm ground to mow on and a stone ledge of sorts around the bottom edge.
Mowing by water can get very bad very quickly; in my case I almost rolled over and buried a 1969 IHC
cub lowboy with a 6 foot belly mower as it slid sideways before I could stop and back up on to firm ground.
Unfortunately, not so often in my area unless they are used up and pretty much scrap metal.
A few points need clarification.
1, the pond is already 95% done so the suggestions of gradual slope are not really helpful. It is very common in my area to have steep slopes because during the very hot dry summer a gradual slope pond will loose lots of surface size, I see it happen to pasture tanks around here all the time. I have 2 other ponds at my weekend place in the woods with steep banks but I don't worry about mowing most of the banks and just let them go wild, other than trees. Bahai grass is commonly used because it has deep roots and can survive the dry summers, springing back quickly with just a little moisture.
2, cost of the additional piece of equipment is a consideration because I just purchased this property last May and have had a large trackhoe and dozer here working for months clearing brush, digging the pond and moving dirt to build a pad for the future home/shop. Plus, I just upgraded my tractor/FEL/backhoe from a B3300/FEL/backhoe. Money is flying out the door and will get worse once the home construction begins.
3, I will turn 64 in January so I'm trying to minimize the physical labor. Hiring lawn crews to take care of the property will most likely be necessary in the future but I like doing things myself. I will not allow large machines on the pond banks by contractors at that point however. I would not want the risk taken by anyone else so hand trimmers would be their machines when that time comes.
4, I do appreciate all the suggestion!!
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
LMC 6' SOIL CONDITIONER (A59823)
LMC 6' SOIL...
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
