light switch replacement on JD 1994 855
   / light switch replacement on JD 1994 855 #1
crdixon
john deere 1994 855
hi:
has anyone out there replaced the light switch (combo switch) on
a JD 1994 855?
our switch shaft does not turn/frozenup.
i had to cut the switch knob off with a dremel as the screw
that holds the switch knob on was frozen/rusted out.
we have the part # and i am evaluating the best access
to the switch.
thanks
cdixon
   / light switch replacement on JD 1994 855 #2
Access is going to be the killer. Hard to get your hands up under the dash to get to anything. May have to remove the fuel tank to gain access. Might also help to hire that guy from the burger commercials with the tiny hands.
JD should have put a cover plate on the side for access...
i looked at the side plate before but removing the tank
is an interesting option.
thanks
cd
   / light switch replacement on JD 1994 855 #4
Look at side panels.
It is even possible to take the whole cluster out without touching the tank.
   / light switch replacement on JD 1994 855 #5
I have the same problem with my switch on my 1990. I also hve a bad cable on the back of my tach/hr meter I guess I better do it all at the same time...got the cable ordered but havent found the part number for the switch.
   / light switch replacement on JD 1994 855 #6
AM876786 SWITCH 1 LIGHT, (SUB FOR AM102356)
2004 CATERPILLAR 836G LANDFILL COMPACTOR (A51406)
2004 CATERPILLAR...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
FAKE (A52472)
FAKE (A52472)
2012 JOHN DEERE 644K WHEEL LOADER (A52705)
2012 JOHN DEERE...
2015 John Deere 7700A Mower (A52377)
2015 John Deere...
