Light switch on B1750
/ Light switch on B1750 #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
Lights on the Kubota just stopped working, the switch is on the left side of the steering wheel - one of those combination switches with flashers on bottom lever and lights on top.
Anyway, the only light that comes on is the tachometer back light, I pulled the switch and it looks like the switch is the culprit. Before I start throwing parts at it I would like to do some more checking, is there a place to find the electrical schema for that old Kubota?
/ Light switch on B1750 #2
These are for a B1700. They are pretty basic, switch sounds like the same one, I can't imagine there is a lot of difference. I did have a problem with my ignition switch a couple of years ago. It was from corrosion on the terminals, cleaned them up, coated with dielectric grease and the problem was solved.
reconstructor24
/ Light switch on B1750 #3
The WSM is printed on such thin paper the ink on the other side comes through on the scans. Sorry. But this is the light switch section. I did have a wiring diagram too, but cannot see that at the moment.
J
/ Light switch on B1750 #5
My headlights on my B7300 stopped working last weekend. The fuses tested OK, so Saturday's project is troubleshooting the switch. These pages ought to make things go a bit smoother. Thanks from me, too.
