Lifting the rear wheels
/ Lifting the rear wheels #1
Texas Dodge
Nursery, Texas
Kubota L3400 4WD
Well today I was moving some dirt and had the bucket on the FEL completely full. I went to back up and the back end was floating all over the place. I was basically balancing on the front wheels like a see saw. The back wheels were completely off of the ground.The back wheels are filled with water and sealant. About 75% of the tire has this mixture and the rest air. Could it be that this bucket for this tractor maybe a little to big for the tractor? I dumped about half out and then everything was ok. I was wondering what you guys would suggest to remedy the problem. I was thinking maybe something to hook up to the three point hitch with some weight.:confused:
/ Lifting the rear wheels #2
You answered your own question there. Hang something heavy off the back, like a box blade or weight box & you'll be fine. It also lowers the stress on the front axle considerably.
/ Lifting the rear wheels #3
I have filled tires and a 830lb boxblade hanging off the back of my L2800. Never a problem with this weight.
Working with just filled tires and no weight hanging off the 3pt will cause major pucker factor.
I even had the back tires off the ground with a 510lb boxblade once...tires were filled then also.
I don't know the exact 3pt weight with filled tires to keep the rears on the ground but 830 does do the trick.
Anyone have any idea how much this 4ft box blade from TSC would weigh?
/ Lifting the rear wheels #5
That is a pretty common situation for me.:D Just do not lower the loader real fast as that gives quite a bump when the rear wheels hit the ground.:D :D :D
Don't worry I lowered the bucket real slow since my butt was puckered;)
/ Lifting the rear wheels #7
@250-300lbs. Not enough nor big enough for your L3400. Your outside tire measurment is 60" for R4 tires, get a 66" min width BB for a little wiggle room on each side.
/ Lifting the rear wheels #8
You could make a ballast box using concrete as the weight.
There are several threads here on making such items inexpensively.
/ Lifting the rear wheels #9
I saw your new tractor post a few days ago and was curious about the loader you had. I did a search and finally found some specs. for it, but don't remember where. If I remember right, the lift capacity on that loader is at least 500 lbs. more than the Kubota LA 463. So, if it does what they say it will do, I would be careful not to overload the front axle.
What size is the bucket on the loader? The factory bucket on the LA463 is 60".
The bucket is 60". I think from now on I will just fill it up half way.
Here are the specs I found. Looks like 557lbs is max.
/ Lifting the rear wheels #12
It appears that this chart is metric. I suspect the 557 is kilograms not pounds. Multiply by 2.2 for pounds.
/ Lifting the rear wheels #13
You can just fill the bucket half way but just for your safety you may still want to get some kind of rear ballast, there will come a day when you get tired of only filling the bucket half way and taking twice as long to get something done.
My L2800 has the 60" bucket and I am able to heap wet clay since it won't fall out like busted up dry clay. I can move more wet dirt than dry. My tooth bar helps alot also.
/ Lifting the rear wheels #14
i generally will not do any fel work without my boxblade (woods 65" - 500lbs) or something else attached (hoe, rake, mower) - anything to counter the weight. just today i was too busy to change out my rake (i think it weighs 250lbs.) for the bb and had a pucker moment when moving some heavy gravel, a couple little bumps/dips in the right place will unweight the rear wheel enough to jump start the heart. another thing i do to minimize risk is to keep the bucket as low as possible when transporting loads, i figure this way i can drop it to the ground very quickly if i get into a sticky situation.
fwiw, my rear wheels are only filled with air.
i would recommend getting at least a 66" bb for the 3400, anything else is just too small.
/ Lifting the rear wheels #15
IF you have a loader, my opinion is that you should fill the rear tires with fluid. You can use a weak water / antifreeze solution for protection to 20F. That will make the machine more stable, less prone to flipping over and will help wiht the lightness.
Then get a rear implement or make a weight box for the 3pt. Target about 5-700#.
jb
/ Lifting the rear wheels #16
bigballer said:
i generally will not do any fel work without my boxblade (woods 65" - 500lbs) ... i would recommend getting at least a 66" bb for the 3400, anything else is just too small.
Does anyone object to dragging a boxblade along with you when you are trying to do loader work?
It seems like I would be able to do my work easier if I used some other technique to weigh down the rear end - water or weights or ???
/ Lifting the rear wheels #17
Greetings,
My L35 has foam filled tires front and back so they add a good bit of weight but the tractor is so strong that even then, when I grab a round bale or pallet that weights around 1800 pounds, I like some extra weight on back.
With the hoe on there, the back end simply doesn't come up.
I have a really heavy box blade that I leave on there most of the time for balance/ballast.
Usually when I am doing loader work, I am smoothing sometimes also with the box blade too so they compliment each other.
With just the weight of the foam in the tires, a full FEL bucket is no problem.
jb
I do have the rear tires filled with water, but the capacity of my bucket is 1225lbs:eek: :eek: :eek:
/ Lifting the rear wheels #19
I run my rear tires filled AND have a 1200# weight on the 3PH. That is about minimum for stability on mine.
Anyone know what the weight capacity is for the front axle on the L3400?
Frontier 4' 3Pt Mower (A66408)
Frontier 4' 3Pt...
2019 FORD F350 4X4 PICKUP TRUCK (A59914)
2019 FORD F350 4X4...
Landhonor 72" Skid Steer Power Rake (A62679)
Landhonor 72" Skid...
2015 VOLVO VN (INOPERABLE) (A65643)
2015 VOLVO VN...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2020 JOHN DEERE 770G MOTORGRADER (A63276)
2020 JOHN DEERE...
