Lifting Heavy Objects
/ Lifting Heavy Objects
When I have 110 pounds of weight on my rear bumper, the relief valves kick in before the pucker factor. They do work but are set a little higher that the pucker factor.
Bob Rip
/ Lifting Heavy Objects #12
That's great info to know...
I'm pretty sure that I'll load my rear tires, which should add about 125 lbs or so, though not out as far from the fulcrum as your weight hanging off the back hitch. I have wheel weights that I can bolt on temporarily, to see what the result would be, before I load the tires with WW fluid. That's the experiment I have in mind, since wheel weights function much like loading the tires -- they're just a pain if you want to remove the wheel to clean off the wheel motors, for example... so, they'd be temporary.
Like you, I just can't see where another 100 - 150 lbs on the back will have that big of an impact on the reliability of the tractor's pivot pin or steering. Every garden tractor I have has the rear tires loaded, and I hang an additional counterweight on the rear when using heavy front attachments like a 42" snowblower.
I want to be able to safely lift the max weight the tractor's hydraulics can handle, on level ground, since I'll have to lift lower amounts in my woods because of the pucker factor caused by the slopes. There's a few spots, like down by the lake, where I must work facing downhill if I work at all -- much like you've described working in/near the creek. I don't want the rear end lifting on a slope, just because there's more hydraulic power than there is weight to hold it down...
Clint Blake has filled his rear wheels. Prior to that he was somewhat disatisfied with his 422. He now is happy with it. Even if you are only carrying say 300 pounds, it gives the rear wheels more traction and keeps you from getting stuck. With some other four wheel drives, if the weight is shifted then the torque can go to the loaded wheels. With the hydraulic drive the torque will not shift to the loaded wheels. I like the weights since they can go on an off in seconds. Normally I only run 55 pounds, and that works pretty good.
Bob Rip
/ Lifting Heavy Objects #14
</font><font color="blue" class="small">( I'm pretty sure that I'll load my rear tires, which should add about 125 lbs or so )</font>
<font color="red"> /forums/images/graemlins/shocked.gif At 8# per gallon you'll need 16 gallons of water for 128#! How will you fit 8 gallons into each little PT-425 rear tire!!??!! /forums/images/graemlins/confused.gif </font>
/ Lifting Heavy Objects #15
</font><font color="blue" class="small">( </font><font color="blueclass=small">( I'm pretty sure that I'll load my rear tires, which should add about 125 lbs or so )</font>
)</font>
And if you can, do you really want to deal with 150 pounds every time you need to change a flat? After having the pt for two years, the repair I have had to do the most often is change flat tires out in the field.
I think you need a total of 125 pounds. 110 pounds on my bumper is enough.
BobRip
/ Lifting Heavy Objects #17
</font><font color="blue" class="small">( I think you need a total of 125 pounds. )</font>
<font color="red"> Since I already have 7# of air in each rear tire, all I have to do is use my compressor to add an extra 55# of air to each tire!! </font>
/ Lifting Heavy Objects #18
I'm guessing that 23x10.50s will hold between 7.5 and 8 gallons -- I KNOW that 23x8.50s will hold around 6.5 gallons since I've done it several times...
While still leaving a large enough air pocket above the rim to soften the ride and adjust the pressure, BTW...
/ Lifting Heavy Objects #19
My guess is you are correct in thinking they will hold 7.5+ gal. I put 5 gal in each of my tires and it did not come up to the valve stem with the tire rotated to have the valve stem at the top. As far as dealing with the weight if you have a flat, I don't know how much the tires on my 1 ton van or my wife's excursion weigh, but I am sure they weigh at least 50 to 60 pounds and I deal with those every time I rotate tires. I have had nothing but positive results from loading my tires and I didn't even reverse them on the tractor.
/ Lifting Heavy Objects #20
</font><font color="blue" class="small">( My guess is you are correct in thinking they will hold 7.5+ gal. I put 5 gal in each of my tires and it did not come up to the valve stem with the tire rotated to have the valve stem at the top. As far as dealing with the weight if you have a flat, I don't know how much the tires on my 1 ton van or my wife's excursion weigh, but I am sure they weigh at least 50 to 60 pounds and I deal with those every time I rotate tires. I have had nothing but positive results from loading my tires and I didn't even reverse them on the tractor. )</font>
<font color="green"> </font> I was not being critical when I brought up the weight problem when changing flats, just bringing attention to it.I was thinking of the time last year when I carried a spare on my shoulder for about half a mile back in the woods after getting a flat. You know what though? I bet you could build a spare tire carrier on the back of the PT and that would add even more weight.
2020 BOBCAT E42 MINI EXCAVATOR (A60736)
2020 BOBCAT E42...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
MASSEY FERGUSON 255 TRACTOR (A62130)
MASSEY FERGUSON...
LIGHT TOWER (A56857)
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2012 Ford F-350...
MAGNUM POWER PRODUCTS LIGHT PLANT (A60736)
MAGNUM POWER...
