Lifting attachments with forklift - anyone install lifting points?
   / Lifting attachments with forklift - anyone install lifting points? #1
Lower40
Champlain, NY
I find it a pain to move my 3 point attachments for storage or loading them on a trailer etc. They normally don't have natural balanced lifting points.
Anyone come up with optional brackets fitted to the attachments that my forks could slide into. I'm sure I could fabricate something...but looking for any ideas already out there.
   / Lifting attachments with forklift - anyone install lifting points? #2
I have built wooden frames for all of my implements that I store in pallet racking. The runners are made of landscape timbers, and the cross pieces are made of 2x4's or whatever I had laying around. Each frame is made for a specific implement. For unstable implements like the tiller I put a ratchet strap over it to hold it to the pallet. Not all implements are able to have a lift ring put on the center of gravity. Also if I used lift rings then I would have to get off the tractor to hook them up. Its much easier to lift the pallet off, turn around, hook up the implement, then toss the pallet back on the rack.
   / Lifting attachments with forklift - anyone install lifting points? #3
I use a front quick hitch adapter and move them with the loader.
   / Lifting attachments with forklift - anyone install lifting points? #4
I do something similar with oversized pallets that I’ve found, a pallet jack to move the around on the ground and pallet racking and forks. Some pallets I cut down to better fit my implements.
   / Lifting attachments with forklift - anyone install lifting points? #5
I use my bolt on grapple to pick them up.
   / Lifting attachments with forklift - anyone install lifting points? #6
I have forks, a grapple, and hooks on my loader bucket yo move things around. I find a chain and hooks on the bucket work the best.
   / Lifting attachments with forklift - anyone install lifting points? #7
Nearly every attachment i have sits on a wooden or plastic pallet. Easier to store and move
   / Lifting attachments with forklift - anyone install lifting points? #8
Most guys I know set their implements on a pallet of some form so they can easily pick them up with the forks on their loader and move them around. Some use scrap wooden pallets, others use plastic ones, others build their own custom pallets out of lumber or steel. If you're going to install lifting points, I'd try to find a way to do it such that you didn't need to get off the tractor to hook up or unhook from each implement.
   / Lifting attachments with forklift - anyone install lifting points? #9
I had the same issue and ended up using pallet rack uprights to build a custom bracket system. Super sturdy and easy to adjust. Welded sleeves that slide over the forks and bolt onto the uprights. Works great for lifting awkward 3-point attachments safely and keeps everything balanced during transport.
   / Lifting attachments with forklift - anyone install lifting points? #10
Same. Built 2 of those. First was the mount for a snow plow. 2nd was to replace the first when I sold that plow & tractor. I use it occasionally, but not that often these days. A deck over trailer makes loading things so much nicer without sides or fenders.
View attachment 3285420View attachment 3285419View attachment 3285418
View attachment 3285423View attachment 3285422View attachment 3285424
2017 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2010 INTERNATIONAL DURASTAR 4300 SWEEPER TRUCK (A51406)
2010 INTERNATIONAL...
2006 JLG 600S MANLIFT (A52706)
2006 JLG 600S...
New/Unused CFG Industrial MH12RX Mini Excavator (A54865)
New/Unused CFG...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
