Lifting 1,000 Gallon Propane Tank.....
   / Lifting 1,000 Gallon Propane Tank..... #1
Utopia Texas
Platinum Member
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
Had my local propane vendor come and pump out a 50 year old 1,000 gallon tank today that is no longer legal to fill. Lucky it was the type tank with a pipe to the liquid in the bottom as there was 700 gallons still left and I get credit for the propane. Lifted the tank into their trailer with no problems using the NH T 4.75. :)
   / Lifting 1,000 Gallon Propane Tank..... #2
I could find all sorts of great projects for a 1,000 gallon tank like that.
Home made submarine, huge BBQ pit, storage for diesel fuel......
   / Lifting 1,000 Gallon Propane Tank..... #4
Pumkin chunkin gun
   / Lifting 1,000 Gallon Propane Tank..... #6
Scrap metal dealer for $$$?
   / Lifting 1,000 Gallon Propane Tank..... #7
Dock float, smoker, culvert, water trough, sap pan.....oh yeah, i'd hate to give it up
   / Lifting 1,000 Gallon Propane Tank..... #8
Turned my old 500 into a pig scalding tub.
I phoned two local scrap yards and was told by both they do not accept propane tanks even if they know they are empty. Too much OSHA, lawyers, liability issues. My propane distributor says he knows a guy who knows a guy who knows a guy......
   / Lifting 1,000 Gallon Propane Tank..... #10
These tanks are quite easy to make safe. Take out all the valves etc and put it in the middle of a large field. Surround the tank with straw bales and light the bales. The heat from the bales drives all of the propane out and then you can cut it up with a torch. I have one that has had diesel in it that I need to make safe.
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
2010 FREIGHTLINER M2 BUSINESS CLASS CAB AND CHASSIS (A52472)
2010 FREIGHTLINER...
Adams 8 Ton Weigh Hopper (A52748)
Adams 8 Ton Weigh...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52748)
Mitsubishi FG35...
