Lifting 1,000 Gallon Propane Tank.....
   / Lifting 1,000 Gallon Propane Tank..... #1
Utopia Texas
Platinum Member
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
Had my local propane vendor come and pump out a 50 year old 1,000 gallon tank today that is no longer legal to fill. Lucky it was the type tank with a pipe to the liquid in the bottom as there was 700 gallons still left and I get credit for the propane. Lifted the tank into their trailer with no problems using the NH T 4.75. :)
   / Lifting 1,000 Gallon Propane Tank..... #2
I could find all sorts of great projects for a 1,000 gallon tank like that.
Home made submarine, huge BBQ pit, storage for diesel fuel......
   / Lifting 1,000 Gallon Propane Tank..... #4
Pumkin chunkin gun
   / Lifting 1,000 Gallon Propane Tank..... #6
Scrap metal dealer for $$$?
   / Lifting 1,000 Gallon Propane Tank..... #7
Dock float, smoker, culvert, water trough, sap pan.....oh yeah, i'd hate to give it up
   / Lifting 1,000 Gallon Propane Tank..... #8
Turned my old 500 into a pig scalding tub.
I phoned two local scrap yards and was told by both they do not accept propane tanks even if they know they are empty. Too much OSHA, lawyers, liability issues. My propane distributor says he knows a guy who knows a guy who knows a guy......
   / Lifting 1,000 Gallon Propane Tank..... #10
These tanks are quite easy to make safe. Take out all the valves etc and put it in the middle of a large field. Surround the tank with straw bales and light the bales. The heat from the bales drives all of the propane out and then you can cut it up with a torch. I have one that has had diesel in it that I need to make safe.
1969 JOHNSON J25 GOOSENECK TRAILER (A51222)
1969 JOHNSON J25...
AMG M 35 A2 C drop side 2 1/2 ton 6 x 6 truck (A50323)
AMG M 35 A2 C drop...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
