lift
jhooks
iseki tx 1000
my lift raised up but wont go down
There is a rate of drop of 3-point knob , usually in front of the operator with rabbit and turtle marked on. If it is all way shut in the direction of turtle then the 3 point would not go down.
No idea what lift or what piece of equipment you are working on. So....maybe a little more detail
My Bendpak has air locks, I need to raise the lift a little to take the load off the locks before I can unlock and lower the lift. The air locks need 30 psi or they will not release. I'm sure the manual lock release also need to be unloaded before they will release.
Too much Viagra??
Sorry... Door left wide open by OP and I couldn't resist........
Too much Viagra??
You could certainly could drive a semi through it. Op needs to elaborate a bit more so we can be more helpful.
By the way, how do you like your MX-4700? not a whole bunch of it around in comparison to 5100.
/ lift
mine is a iseki tx1000. i used the lift to raise a trailer tongue it stopped at the upmost position and wont come down. any suggestions woul be greatly appreciated.
Hi JC-jetro. I feel like the MX series is a good all-arounder, big enough to do some decent work and yet small enough to be fairly maneuverable and fit into smaller spaces. There are other machines I would like to have but this suits my needs quite well.
I went with the non turbo for simplicity sake. I do not need the extra horse power and felt that the extra cost and complexity would be wasted in my situation. I also like the fact that everything is mechanical on this machine and it is fairly simple to work on.
Don't mean to hijack this thread but how do you like yours??
To the OP there should be an adjustment knob for the three point hitch lowering speed somewhere around the seat area. Could be that someone accidentally adjusted it somehow?
Could it be that there is not enough tongue weight on the trailer hitch to lower the 3 point hitch. It does not have down force and moves downward by gravity.
I thought you were talking about a vehicle/car lift, sorry.
The OP is MIA for now. Hope he chimes in with a bit more info so we all can help him.
I love my MX foor all the reasons you said, and having naturally aspirated was one thing that I wanted. Yup, electrical /mechanical all very simple and CATII 3 point lift is great, just wished it had the deluxe extendable lift arms. I am sure it will outlast me.
How much weight is on the tongue? If it is close to balanced, there moght not be enough weight to drop it. When my old Iseki built MF1250 didn't have anything on the 3PH I had to push the arms down to get them to lower.
Yes, would need more information from OP to be helpful.
I agree, those extendable arms would come in handy and I have considered getting them since they are still available at the parts counter.
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
RAIN FLOW HOLE PUNCH, 3PT (A63291)
RAIN FLOW HOLE...
2013 Mercedes-Benz GL450 AWD SUV (A61574)
2013 Mercedes-Benz...
2015 Ford Transit 250 Cargo Van (A61573)
2015 Ford Transit...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
