Lift too fast not smooth
   / Lift too fast not smooth #1
Preston ms
Massey ferguson
I have a 1999 New Holland TC29 that the lift on 3 point hitch is to fast on the down side. I looked for an adjustment but can’t find one.
   / Lift too fast not smooth #2
I think there is drop rate control knob just below the seat. Close to slow drop speed open to increase.
   / Lift too fast not smooth #3
Yes there is indeed a flow control knob just below your seat:
   / Lift too fast not smooth #4
The rate of drop only regulate the return fluid back to lift spool and then to diffy housing. The supply flow actually enters the lift cylinder area from a different passage way. the hole in the middle is for return and the hole on the left is for supplying fluid to lift the 3 point. This pic is on 1700 but concept is the same. The very hole on the left is shock relief oil return.
Edit:Just turn the knob clockwise to pinch the valve down and it would come down slowly. If you do it all the way then you cannot lower the 3 point.
  • TC-29.pdf
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A57453)
2012 Mitsubishi...
2019 Komatsu WA380-8 Wheel Loader, S/N A75147, PIN# KMTWA130TKNA75147, Turbo Diesel Engine, Komatsu (A59076)
2019 Komatsu...
2012 International Derrick Digger (A55973)
2012 International...
2011 Kubota KX080-3 Midi Excavator (A56857)
2011 Kubota...
(2) AIR OVER HYD JACKS (A58374)
(2) AIR OVER HYD...
6' SCRAPE BLADE (A52708)
6' SCRAPE BLADE...
