Lift or mechanic's pit for new garage?
   / Lift or mechanic's pit for new garage? #111
Why a lift can be handy. The tech told me it was cheaper and faster to lift the cab to replace the turbo
   / Lift or mechanic's pit for new garage? #112
Why a lift can be handy. The tech told me it was cheaper and faster to lift the cab to replace the turboView attachment 4420384
It is so wrong on so many levels that routine vehicle maintenance requires a cab removal. That's even worse then pulling a pickup bed to change a fuel pump. Or here it the rust bucket NE cutting an access panel in the bed to get to it, because you know that most of the bead mount bolts will not come out.
Guess how those cab bolts will be in a couple of years.
   / Lift or mechanic's pit for new garage? #113
I hear ya. Even venerable Toyota PUs had many problems with rusty frames, and not just from the Rust Belt. It may be safer to lift a truck bed off a rusty frame, vs. lifting the whole vehicle with a floor lift.
I don't have helpers, so I depend heavily on machines to make this possible. Sometimes, I use the tractor and boom pole on the loader to pull a bed or engine or FOPS or FEL, but an overhead hoist is usually better.
I do a lot of ATV work and it is really nice to lift the whole unit onto a rolling cart that limits the amount of bent-over work necessary. And they roll right over my diamond plate pit cover, no problem.
   / Lift or mechanic's pit for new garage? #114
I have 1", 3" and 6" extensions and it is still a pain at times. I find SUV's like Highlanders the worst and the odd thing is they are never used by occupants like they are used on trucks.
LOL!
Yeah nothing is really a perfect set up!
   / Lift or mechanic's pit for new garage? #115
Once you realize that at the factory they drop the cab and bee onto the rolling chassis, and there are quick connects for all the electrical pulling the cab is lots easier. Unless of course you’re a space alien, with an extra wrist located about halfway down the forearm from the elbow.
   / Lift or mechanic's pit for new garage? #116
If you want a light use pit, find a tornado shelter company many offer in floor versions that can double as a pit.
Then insurance companies think it's a shelter, and it can be used as one.
   / Lift or mechanic's pit for new garage? #117
That's the best argument for a pit I have seen :)
   / Lift or mechanic's pit for new garage? #118
A good pit will cost much more then a hoist, more then even two hoists.
Built much the way the Lube shop pits are. Sturdy foots and walls with a strong precast floor set on it. Lots of room well light and ventilated with an adjustable step up platform to get to the right height.
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
New/Unused Pallet of Ground Protection Mats (A57454)
New/Unused Pallet...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
Eaton Air Compressor (A56857)
Eaton Air...
