lift arms
   / lift arms #1
Bob Morrow
New Concord,Ohio
david Brown
I have a David Brown 1212 with a lift arm control problem. When you push the control lever to lower the arms they come up. Any ideas?
   / lift arms #2
Try posting this in the Case forum too, I believe the 1212 DB and the 1210 Case are the same tractor... The only thing I can think of (and don't take my word on it, I've never worked on either brand) would be if you have a diverter valve or something similar to send power to your remotes, it could be malfunctioning (leaking through the spools) or in the wrong position. Unless (if it's like the Massey's), you've had the lift cover off, in which case the levers that actuate the valve body on the pump could be in the wrong spot. They can be a PITA to get back where they belong
   / lift arms #3
I have run into this with case david brown and a allis chalmers. Have you made sure that the depth control linkages are free and working properly?
2016 Freightliner Gradall D152 Truck Mounted Excav (A53117)
2016 Freightliner...
PAIR OF 7' HOOK ON TRAILER RAMPS (A51247)
PAIR OF 7' HOOK ON...
CASE IH 2412 - 12R CORN HEAD (A51247)
CASE IH 2412 - 12R...
2012 CATERPILLAR 316EL EXCAVATOR (A51246)
2012 CATERPILLAR...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
2022 KMC 5610 LOT IDENTIFIER 236 (A53084)
2022 KMC 5610 LOT...
