Lift arm replacement need it...
/ Lift arm replacement need it... #1
Bluecheck546
SE Georgia
04 2015 Mahindra
Hi I'm looking for a drealer who would sell me a right (as sitting on the tractor)
lift arm. I bend it a while back, straightened it out and it is bend again. It is for 2015 geared transmission. Thanks.
/ Lift arm replacement need it... #2
Do you have a local dealer? The part # listed in my book is 1963 2414 BR1 Lift Arm RH. I'm not a dealer but have the parts and service manuals.
Thanks for the number, I do have a dealer about 60 miles away, but I'm not impressed with him. I will order from someone else if some other dealer respond. Thanks
/ Lift arm replacement need it... #4
These must be badly heat treated at the factory, Mine came new with the left arm bent down. The dealer replaced it right away. No problem since.. John
After closer inspection I learned that the rockshaft it self is twisted clockwise. Yes, the spline on the right side is twisted, much to my sup rice! I wonder can someone here cross-reference this part to similar cub cadet tractor. This is for 2015 geared Mahindra.
/ Lift arm replacement need it... #6
Bluecheck546,
The shaft that the lift arms are attached to is a one piece shaft that goes all the way through the hydraulic case with a lift arm on each side. It is part # 1963 2409 000 Hydraulic shaft. # is the same whether gear or HST. I don't know Cub Cadet part#. I'll send you a PM.
George
2022 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2022 CATERPILLAR...
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
2023 Deere 325G (A60462)
2023 Deere 325G...
2015 John Deere 710K 4x4 Extendahoe Loader Backhoe (A61572)
2015 John Deere...
2014 Ford Focus Sedan (A61574)
2014 Ford Focus...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
