lift arm length
   / lift arm length #11
I have a DX33 with a 5 ft KK. Since the pins on the KK are pretty high my tractor does not lift the implement very high. My lift arm has three pin holes to adjust with on the left side so I move to another hole to get the higher lift. Of course the right side is adjusted with the crank. Perhaps if your tractor has the extra holes you can restrict how high it lifts that way if necessary.
   / lift arm length #12
If you don't want to go the cost or have them on there all the time (the quick hitch which would give you an inch or two) you could have extensions welded on the cutter to move the lift pins forward. Don't forget to be sure the pto shaft is still long enough.
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2007 INTERNATIONAL MA025 DAY CAB (A51219)
2007 INTERNATIONAL...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
2020 MACK PINNACLE (INOPERABLE) (A50854)
2020 MACK PINNACLE...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A49461)
2019 Allmand...
(2) ROLLS OF HD CHAIN LINK MESH WIRE (A50460)
(2) ROLLS OF HD...
