lift arm length
   / lift arm length #11
I have a DX33 with a 5 ft KK. Since the pins on the KK are pretty high my tractor does not lift the implement very high. My lift arm has three pin holes to adjust with on the left side so I move to another hole to get the higher lift. Of course the right side is adjusted with the crank. Perhaps if your tractor has the extra holes you can restrict how high it lifts that way if necessary.
   / lift arm length #12
If you don't want to go the cost or have them on there all the time (the quick hitch which would give you an inch or two) you could have extensions welded on the cutter to move the lift pins forward. Don't forget to be sure the pto shaft is still long enough.
INGERSOLL RAND 100KW GENERATOR (A50854)
INGERSOLL RAND...
Stainless Steel 1" Spool (A49461)
Stainless Steel 1"...
2015 GMC Arcadia (A50324)
2015 GMC Arcadia...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
MAGNUM PRODUCTS LIGHT TOWER (A50854)
MAGNUM PRODUCTS...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
