3-Point Hitch lift arm ajusters
/ lift arm ajusters #1
gravelman
Platinum Member
NH
Kubota 2650
Hi folks..gravelman from NH The small Kubota tractors have turn buckles for adjusting the lift arm swing...they are a pain in the butt. My 2650 has a nice sliding adjuster with pins..very easy to use. Does anyone know of an adjuster that could be used on the small Kubotas or the brand of a tractor that has easy to use adjusters???? thanks alot
/ lift arm ajusters #2
The parts you are seeking are Lower Link stabilizers, specifically pin adjustable, rigid, Lower Link stabilizers.
I believe pin adjustable, rigid, Lower Link stabilizers are now an option for Kubota BX tractors, so you should be able to order same from a Kubota dealer. Will not ease mounting Three Point Hitch implements much because BX sized 44" to 48" implements are light enough to jockey around 1/2" manually, to line up Three Point Hitch bull's eyes with implement pin holes.
Rigid stabilizers would be useful if you desire to push SMALL amounts of dirt with a Box Blade, or Rear/Angle blade in reverse orientation. However your heavier B2650 will perform these pushing tasks more efficiently.
Bear in mind Kubotas have METRIC fittings.
/ lift arm ajusters
Fantastic...thanks for that quick reply..i knew there must be an alternative
/ lift arm ajusters #4
With some good measurements and diligent searching you can probably find a pair from another tractor model that will fit.
I built a pair for my JD2210. Great addition.
For some reason I can't post pics right now. I'll come back later and post some.
/ lift arm ajusters
ok, sounds good
/ lift arm ajusters #6
Here's my pics. The turnbuckles in the first pic is what my tractor was built with.
/ lift arm ajusters
Fantastic...this is exactly what i have on my Kubota 2650 i wish they would do them all like this. THANK YOU VERY MUCH
/ lift arm ajusters #8
Would adjusting these arms help my problem? The implement, currently a 5 foot bush hog, is canted off to the left. Nothing I do can seem to get it tracking straight behind the tractor. So do I need to adjust the left turnbuckle?
/ lift arm ajusters #9
If mower is canted left, snug up RIGHT stabilizer to draw it to center.
Is the tail wheel free to turn in every direction?
/ lift arm ajusters #10
Ok, thanks. Yes the wheel is free to (and does) turn in every direction. It moves 360 degrees depending on if I turn left, right, back up etc.
/ lift arm ajusters #11
Does not good to snug up the right stabilizer if you don't loosen the left.
2022 KUBOTA SVL75-2 SKID STEER (A65053)
2022 KUBOTA...
2022 EZ-GO ELITE...
Crane Carriage System for Steel Baskets (A65579)
Crane Carriage...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
John Deere 825 6R Cultivator (A66408)
John Deere 825 6R...
Mahindra Emax 22S Loader Tractor (A66285)
Mahindra Emax 22S...
