3-Point Hitch lift arm ajusters
/ lift arm ajusters #1
gravelman
Platinum Member
NH
Kubota 2650
Hi folks..gravelman from NH The small Kubota tractors have turn buckles for adjusting the lift arm swing...they are a pain in the butt. My 2650 has a nice sliding adjuster with pins..very easy to use. Does anyone know of an adjuster that could be used on the small Kubotas or the brand of a tractor that has easy to use adjusters???? thanks alot
/ lift arm ajusters #2
The parts you are seeking are Lower Link stabilizers, specifically pin adjustable, rigid, Lower Link stabilizers.
I believe pin adjustable, rigid, Lower Link stabilizers are now an option for Kubota BX tractors, so you should be able to order same from a Kubota dealer. Will not ease mounting Three Point Hitch implements much because BX sized 44" to 48" implements are light enough to jockey around 1/2" manually, to line up Three Point Hitch bull's eyes with implement pin holes.
Rigid stabilizers would be useful if you desire to push SMALL amounts of dirt with a Box Blade, or Rear/Angle blade in reverse orientation. However your heavier B2650 will perform these pushing tasks more efficiently.
Bear in mind Kubotas have METRIC fittings.
/ lift arm ajusters
Fantastic...thanks for that quick reply..i knew there must be an alternative
/ lift arm ajusters #4
With some good measurements and diligent searching you can probably find a pair from another tractor model that will fit.
I built a pair for my JD2210. Great addition.
For some reason I can't post pics right now. I'll come back later and post some.
/ lift arm ajusters
ok, sounds good
/ lift arm ajusters #6
Here's my pics. The turnbuckles in the first pic is what my tractor was built with.
/ lift arm ajusters
Fantastic...this is exactly what i have on my Kubota 2650 i wish they would do them all like this. THANK YOU VERY MUCH
/ lift arm ajusters #8
Would adjusting these arms help my problem? The implement, currently a 5 foot bush hog, is canted off to the left. Nothing I do can seem to get it tracking straight behind the tractor. So do I need to adjust the left turnbuckle?
/ lift arm ajusters #9
If mower is canted left, snug up RIGHT stabilizer to draw it to center.
Is the tail wheel free to turn in every direction?
/ lift arm ajusters #10
Ok, thanks. Yes the wheel is free to (and does) turn in every direction. It moves 360 degrees depending on if I turn left, right, back up etc.
/ lift arm ajusters #11
Does not good to snug up the right stabilizer if you don't loosen the left.
Yale 5K Forklift (A63689)
Yale 5K Forklift...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
2025 MACK GRANITE GR64F DUMP TRUCK (A63276)
2025 MACK GRANITE...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
