levelling ground after discing??
   / levelling ground after discing?? #1
HCJ
upstate South Carolina
Kubota M6800 4WD
After I disc up a food plot, the ground is of course fairly irregular. I made a drag harrow out of 3 pieces of heavy angle iron linked together with chain and then drag it around, and this works pretty good. My question is do any of you guys attach a drag harrow to the back of the disc harrow to do this in one operation? I have heard of people doing this and just wondered if it is practical, to save time and laps around the plot. If so, is there any way to lift it with the disc, or does it just drag. A problem I may have is turning it around. Just curious if there is a better was to do this. I have often wondered if a good pulverizer or cultipacker would help. Of course this would have to be used independently as a separate step.
   / levelling ground after discing?? #2
I made a drag out of old truck tires. I chain them together and just drag them behind the disc. Keep them about six feet behind the disc.
Any trouble turning around? a lot of my plots are long and narrow and I am afraid that turning would be an issue. After using your tire drag, are you ready to plant. in other words, do you do anything else before broadcasting seed?
   / levelling ground after discing?? #4
Turns are a bit wider with the tire drag attached. Just slow down. I just toss the seed out afterwards and pray for rain. Food plots always came up well.
   / levelling ground after discing?? #5
my neigbor has a 8" diameter log attached behind his 7' disc for crushing and leveling the dirt. does not compromise turning radius.
   / levelling ground after discing?? #6
After I used my neighbors disc to turn the soil over I chained a couple of pallets to the tractor and then dragged them over the field a couple of times to break up the clumps and flatten things out. Drag the pallets upside down and you will get a nice smooth surface. I then used a spike harrow at a medium setting to get some nice grooves for the seed to go into. After I broadcast the seed I then used a piece of chain link fence attached to a 4x4 and dragged that over the seeds. It worked well and everything came up fine. I hope this helps.
   / levelling ground after discing?? #7
I made this one so I could lift it so turning and transporting it wouldn't be an issue.
Here's a place or two I've smoothed up with it
1*I then used a spike harrow at a medium setting to get some nice grooves for the seed to go into. After I broadcast the seed I then used a piece of chain link fence attached to a 4x4 and dragged that over the seeds. It worked well and everything came up fine. I hope this helps.
I'd like to get this one rigged up so I can lift it and carry it with my 3 point hitch.
   / levelling ground after discing?? #8
Two issue with that. One, that's not attached behind a disk.
Two: pull something like that behind fluffy,disked soil and it's just going to plow into the dirt.
Most things pulled behind a disk are going to drag and not be something that can be lifted. It just takes a larger turning radius (assuming you're using a 3 pt disk), though that isn't always easy. A cultipacker may help a little, but it doesn't help much as far as leveling.
   / levelling ground after discing?? #9
1* One, that's not attached behind a disk.
2*Two: pull something like that behind fluffy,disked soil and it's just going to plow into the dirt.
Haven't had either issue
1* & 2* Have used it several times and never ran into either issue.
   / levelling ground after discing?? #10
Sorry LB , But no wonder youve never ran into an issue.
#1 Its a Really small pallet with concrete blocks on it for weight .
#2 Its pulled behind a little bitty tractor .
#3 It has nothing to do with the OP question of dragging behind a disk .
#4 I would think a hand rake would do the job much better in your situation . :rolleyes: .
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
2006 Toyota Tundra 4X4 Pickup Truck (A53422)
2006 Toyota Tundra...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
MISC PALLET OF DRIVELINE PARTS (A55745)
MISC PALLET OF...
