levelling box: can't adjust!!
   / levelling box: can't adjust!! #1
mauricem
QLD AUSTRalia
MF 253
Ive discovered a strange problem with my recently acquired MF253 which I cant work out. Basically the handle for the levelling box on the rear hitch cant be used as it fouls on either the mudguard or the ROPS frame. It all looks original eg proper guards and genuine MF ROPS but for some bizzare reason there is not enough space between the handle and these parts to turn it.
If I drop the linkages to the lowest level and swing the arms to the far left I can just turn the handle but this is clearly unworkable for doing fine adjustment work needed when using a box blade or similar.
Short of taking a hacksaw to the handle any ideas?? The handle doesnt look too short or different to the one described in the manual. I cant help but think I must be missing something obvious but I dont know what! Happy to be called an idiot if I can only get it to work!
   / levelling box: can't adjust!! #2
Maurice:
If you lift that clip that is around the base of the handle, will the handle swivel in the base so you can turn it without interference?
   / levelling box: can't adjust!! #3
Looks bent here. Might just be the photo angle. If that part of the handle "wobbles" from side to side as you crank it, that is probably the problem.
Bruce
thanks for the suggestion, I should have mentioned I had tries it with the clip in all positions. Just had another look then and was thinking maybe the handle has been bent at some stage but its a very solid piece of steel and to bend it accidentally in situ in reverse would seem improbable and scary!
Bruce
was typing the same as you posted! Only difference is Ive had over a year to contemplate the problem vs your couple of minutes!
Thanks and yes it is slightly ecentric when rotated as far as I can
   / levelling box: can't adjust!! #6
By looking at the photo, that can not be the original. Something had to be replaced.
See if someone else has the same unit and compare.
   / levelling box: can't adjust!! #7
if moving your lift arm just a few inches gives enough room to turn the handle you might turn the pins on the blade inward so your lift arms are narrower.
But i agree that most likely the handle is bent.
what part doesnt look original? the handle or the whole assembly?? Here's a screen cap from the manual. Not sure if these are to scale but I'll measure relative dimensions in the morning and see if it aligns.
I'm the 2nd owner of the tractor it came off a flatland golf course and seems to be very original ie anything that needed fixing was replaced by dealer.
I'll see if I can track down a compatible 200 series and compare the setup. thanks for the suggestion.
   / levelling box: can't adjust!! #9
It seems there's a third bend in the OP's handle, as in right where it comes out of the box. (maybe the lads who mowed the GC were only good at going foreward)
At worst, 'blue wrench' repair might only cook some grease inside the box. (Wouldn't take much to over-think this .. :confused3:) An easy fix, no?
UNUSED FUTURE FT1000J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2024 JOHN DEERE 4044M LOT IDENTIFIER 62 (A53084)
2024 JOHN DEERE...
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
