Leveling topsoil for new lawn
   / Leveling topsoil for new lawn #1
lzicc
Platinum Member
Pittsburgh, Pa
Kubota B2650
I relandscaped my side and back yard and have it close to almost finished. I am waiting for september to plant grass seed. I will need to purchase at least 4 tandem truckloads of topsoil. I am going to get the screened topsoil and have mushroom mulch mixed in, like a 50/50 mix. What would be the best way to spread this so I would have very little hand spreading to do? I have a box blade, but though about getting a 3 point landscape read to help level it off.
I will initially spread the topsoil out using the fel and get it somewhat leveled off, but once it is spread, what could I use for the final leveling off? Also, since most of the yard is on a grade, what would be good to use to cover the grass seed to keep it in place until it grows? I have straw, but if it rains really good, I don't know how well that will hold the seed from floating away.
   / Leveling topsoil for new lawn #2
The best thing I've found to do the "final" leveling is a spike tooth harrow. If there are clumps of soil/mulch mixed into the topsoil, this will help break them up, and assist in the final grading. (this assumes you get the topsoil pretty well distributed with your FEL and box blade)
But for the best finish, turn the harrow upside down, with the spikes facing upward. Go over the area 2-4 times depending on how level you want it, plant your seed, and go over it once again with the harrow to bury the seed. Did this on my 10 acres, and it works great, even on hills.
Since the topsoil will already be screened, I wonder if this drag harrow would work if I can get the topsoil down well with the fel.
   / Leveling topsoil for new lawn #4
I have found with a little finesse with the bucket works best for me, finish it with a drag harrow if you have room otherwise a hand rake..
   / Leveling topsoil for new lawn #5
I would think that drag would go a great job. Around here, they use a bobcat fitted with pallet forks and they put a pallet on it and drive it around with the front of the pallet slightly raised and the back touching the ground. My concern is driving those really heavy trucks over your driveway. Where are they going to dump the dirt?
They can back up the driveway and backup to the side yard. The back yard I will have to move it up there with my fel. I did think about the pallet idea. That is a good idea also.
   / Leveling topsoil for new lawn #7
A LPGS (land plane) works excellent for good fresh topsoil. Especially with a hydraulic toplink so you can adjust the pitch on-the-fly.
I do a lot of this work with my landscape company (topsoil prep for sod/seed) and if the material is dry, and there's adequate space for a tractor to move around, the LPGS works wonders.
   / Leveling topsoil for new lawn #8
Perfect way to finish it after that is with a Landscape Tiller (ATI Preseeder is what I use). Very expensive tool ($12k) but the finished product is very nice.20190511_105822.jpeg20190511_105832.jpeg20190511_170837.jpeg
   / Leveling topsoil for new lawn #9
For me, nothing works better at shaping, moving material and final finishing the ground then my front bucket. I back drag it and adjust the angle of the bucket to either dig in, or feather the dirt up. If I need a little more in one area, I dump a little there, back drag it and decide if I need more or not, and do it again and again, until its perfect.
   / Leveling topsoil for new lawn #10
View attachment 615900View attachment 615901View attachment 615902
Mushroom Compost. I used some on my re-planted front yard last fall. This late spring I had a massive crop of mushrooms. I think that is the end of my mushroom composting. They are hard to get rid of due to the millions of spores they drop.
Ron
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
2351 (A58376)
2351 (A58376)
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
Bucket (A56857)
Bucket (A56857)
