leveling the deck
/ leveling the deck #1
Huckridge2
First time to post. Please overlook my ignorance
I have a model 2155 and it appears the deck is low in the front. How difficult is it level these decks? This is the first cub cadet I've owned, got it from a friend for a good price
/ leveling the deck #2
it its normal for the deck to be lower in the front and I think it is recommended for it to be. it is when its un level from side to side you get your uneven cut.
/ leveling the deck #3
"level" is the term used, but it means to adjust the deck height relative to the ground. First put the correct air pressure in the tires, fronts and backs. Then level the height left to right, and finally front to back, with the front about 1/4" lower than the back.
/ leveling the deck
Thanks for the information, I located the owners manual this weekend and discovered the front of the blades should be lower just like you said.
225/70R16 Tires - Set of 4 (A68134)
225/70R16 Tires -...
10ft S/A Cargo Trailer (A66738)
10ft S/A Cargo...
2009 FREIGHTLINER M2 Slick Line (A67714)
2009 FREIGHTLINER...
2014 Ford F-150 Pickup Truck (A66736)
2014 Ford F-150...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
2021 Komatsu PC210L Hydraulic Excavator (A66734)
2021 Komatsu...
