LEVELING old Crop rows
/ LEVELING old Crop rows #1
sportsministryguy
We have several acres that are nicely mowed but have rolling rows that could only be described as old farm crop rows. They are very symmetrical and about 6-8 inches high and 3 feet apart. We have been mowing this area for years and so there is nicely established grass (I am only telling you this to help you understand what the ground is like). We can only mow parallel with the rows (if we mowed perpendicular to the rows it would throw you off the mower)
We want to level the area and then replant grass seed.
I was considering a cross tiller the area with a large power till on a tractor or skid steer and then power rake to do the final grade.
Our ultimate goal is to have a safe place for kids to play.
Am I way off or do you have any suggestions?
HELP!
Doug Rogers
Director of Sports Ministry
Windwood Presbyterian Church
/ LEVELING old Crop rows #2
I would try cutting each row with a single/or double blade bottom plow thereby transfering each ridge into the adjacent hollow. Drag with a disc and then follow with a chain harrow or boxblade. You may be able to skip the disc if the soil conditions are dry and loose. Good luck and let us know how you proceed.
After doing a bit of research what do you think about power tilling with a PTO tiller (both parallel and perpendicular) and then a power rake to level?
/ LEVELING old Crop rows #4
I would skip the tiller and just use a disc. Straddle the ridge and adjust the third arm on your disc (3 PH style) to make the front gang plow more than the back so it throw the dirt into the "ditch" part of the row. Make as many passes as it take to where the land looks level by discing with the row then drag a harrow or whatever you have to smooth it out. The disc will move the soil to the outside edges whereas a tiller is going to leave it in the same hump that it is now. You want something that moves the soil laterally. You may even want to reset the gang level and disc at a 45 to the rows after making a pass or two with the rows. Number of passes with the disc depends on how hard the soil is, and how well the disc cuts.
/ LEVELING old Crop rows #5
It's going to take a lot of passes or a really heavy disk to cut down 6-8" of dirt that's been compacted from years of being a lawn.
If you till at 45 degrees to the rows then at 90 degrees to that it will smooth it out. You'll probably be seasick the first pass but you only have to do it once.
/ LEVELING old Crop rows #6
150 years of J.I. Case - Google Books
For a little history of your field go to page 135 of this site you can see a similar implement that was used to create those ridges. The implement was a Lister and page 135 is titled Planter. Those ridges were referred to as (you guessed it) Lister Ridges. The idea was to place the seed in the bottom between the ridges and as the crop was cultivated the ridges were worked down and filled the valleys back in. As you can see by your field they didn't always come back nice and flat.
If a disc (k) is available it will contact the ridge tops first and loosen that soil. Follow that with a drag with rails at least 6 ft. long and go across the field on the bias in at least 2 different directions to drag soil and grass mixture into the valleys. After some smoothing has been accomplished, disc(k) it on the bias at least once, maybe twice and drag it again. Repeat until you are happy. You'll be the judge and jury on that.
/ LEVELING old Crop rows #7
According to what you have available, or are willing to buy/rent...
I would probably go down the rows with a tiller, at least as a first pass.
Then maybe a second pass at 45 or 90 degrees, that ride would give a good idea of how well the first pass had worked and a second pass is a good idea anyway.
I'm assuming that you have something bigger than a 12 HP "Garden tractor" and can reasonably til sod under.
Yes, a Harley or similar power rake would be good for final grade and if you can lay hands on an old style one with the bars instead of nubs that might be as good as a tiller for the first pass.
Around here it is pretty much the standard old lawn ripper upper tool.
ONE tool may have advantages to you - again, depending on local logistics (& funds).
/ LEVELING old Crop rows #8
For that big of a area i would start over. I would have it plowed then disc and finished with a drag then reseeded. A dozer may also be a option.
Chris
/ LEVELING old Crop rows #9
I think I may be thinking too much here (-:
ONE thing that I am thinking is that this is church property, or property that the church has use of.
Another is that a church member has a tiller & power rake available and has volunteered the use of them - probably a tractor & operator too.
If I am anywhere NEAR close then I think you should probably seize whatever opportunity has sprung up (-:
Your "volunteer" is in a much better position than us to judge the site from the perspective of their equipment, skills and time available.
I would gratefully accept in behalf of the church (-:
As I said, I think I may be thinking (assuming) too much here (-:
/ LEVELING old Crop rows #10
Sounds like a reasonable plan. :thumbsup::thumbsup:
Don't short yourself on the preparation. That is the final ride and it's nice if it is smooth.:D
/ LEVELING old Crop rows #11
If it were mine , I would probably disc once with the rows , once or twice at an angle , then work it with a cultimulcher (heavy two gangs of corrugated rollers with adjustable teeth ) This will level , crumble clods , and firm up the ground
/ LEVELING old Crop rows #12
Here's a simple and fair way to see how "level" and smooth it all is when (you think) you're all done.
Get off the tractor (OUCH !) and kick a very large beach ball around for a while.
You will get a very good idea of just how it will drain and whether you have left subtle whoop de doos, which are often hard to see from high up on the tractor, you don't always feel them in the ride either.
This can work very well for areas where you are trying to make swales for deliberate run-off routing.
Thank you all for your many options and opinions. Lots to consider. :)
We are located in NW Houston. REG - you anywhere close by?
/ LEVELING old Crop rows #14
Hi,
Unfortunately no, or I would already be in contact trying to set up a time to haul my stuff out to you (-:
The closest I have been to Houston recently (2 years ago) was Murchison TX, I think that is some 60 miles east of Dallas - a 3 day drive from where I am in Massachusetts.
I drove through Amarillo on the way to LA about a year before that.
I flew in and out of Houston for a few days, maybe 3, somewhen in the early 70s, I don't remember the customer or the exact nature of the trip.
So, what do you have at your disposal, or what could you easily lay hands on ?
Although you said "several acres" that could mean anything from maybe 2 in RI to 2 hundred in MT - which would likely affect the approach, I think a slightly more precise measure would help us to help you.
/ LEVELING old Crop rows #15
Also depends on what time of year you work it. Our soil is still on the mushy side, but when it gets hotter, it will be like concrete.
/ LEVELING old Crop rows #18
For all the comments, using a tiller only move soil in vertical direction. You can till that area in 47 directions and you will still have the ridges. A disc with a flat drag behind it will do the best job. The perfect drag is an old railroad track that needs to be a foot or more wider than the disc on each side. You can tell by watching the dirt pile on the drag when the field is level. When you have that drag with a fairly level dirt all the way across and not piling up in one section, then it will be level. You could till and pull a drag behind you also but it will be much slower operation than using a disc. My disc has 22" blades on it and weighs more than a thousand pounds. It would have no trouble cutting that ridge down in 2 or 3 passes at most. I would be pulling it at 5 mph vs 1/2 mph with the tiller.
/ LEVELING old Crop rows #19
The use of a disk will be very dependant on the size of tractor available. The small tractors pulling a light disc may not be up to the job when it involves mature sod.:)
/ LEVELING old Crop rows #20
I have a relatively light disk harrow, but I have a pair of 55 gallon drums strapped to it with hose faucets on so I can bottom fill or quickly dump them.
That allows me VERY adjustable ballast - and I don't have to carry it very far (-:
PART of my "depends what you have, or can lay your hands on" approach in conjunction with one of the replies that suggested (to me) that a tiller and power rake may be available.
If that is the case... better a slightly sub optimal solution that is available than the ideal solution that is not (-:
I am ASSUMING that equipment would have to be brought in, probably trailered in.
The IDEAL equipment may not be available within easy reach, or at a practical cost.
Volunteers ?
Anyone close to NW Houston want to go and help out ?
2000 KENWORTH T800 CRANE TRUCK (A67714)
2000 KENWORTH T800...
2022 Kubota 62in Zero Turn Commercial Mower (A66734)
2022 Kubota 62in...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2017 FORD F-150 FOOD TRANSPORT TRUCK (A67714)
2017 FORD F-150...
7ft Fork Extensions (A66734)
7ft Fork...
2013 FORD E-SERIES VAN (INOPERABLE) (A67714)
2013 FORD E-SERIES...
