Leveling Dirt
/ Leveling Dirt #41
1. A landscape rake or reversable rear blade with guage wheels.
2. A drag that allows material to spill over the top of the cutting piece.
/forums/images/graemlins/wink.gif
/ Leveling Dirt #42
/ Leveling Dirt #43
I'd have to go check again but I think the 3pt on my NH TC30 has down pressure (i.e. I can't lift the arms with my hand in most positions) I haven't really checked this but I've of noticed that when I'm hooking up my brush hog I've got to have the arms at exactly the right height, not lower like I used to do with my old Rhino International.
If I remember when I get home I'll check this out.
/ Leveling Dirt #44
/ Leveling Dirt #45
Regarding the float position on the 3 point -- My DX 29 has 3 different areas marked on the 3 point lift control. The upper and lower ones are black with white reference points. The center section is white with black and marked as "float position for mowing". The only thing I've had on the 3 point so far has been a relatively light back blade and my counterweight. With the lift arms set in the center hole, I don't use the lower two areas when blading. My blade is fairly light. It seems that there is more down pressure than would come from simple weight in the upper 1/3 of the control
/ Leveling Dirt #46
/ Leveling Dirt #47
I don't have a bb but I have found that the TR3 has made keeping my wife's arena in shape very easy. It has a blade, teeth and a rake that can all be independently adjusted to suit the soil conditions. http://tr3rake.com/
/ Leveling Dirt #48
John Deere 400 Rotary Hoe (A66408)
John Deere 400...
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2020 FREIGHTLINER 114 SD CEMENTECH VOLUMETRIC MIXER (A65643)
2020 FREIGHTLINER...
Generator Cord (A65640)
Generator Cord...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
