Level Indicator Mounting
/ Level Indicator Mounting #1
STEVEG
MARLBOROUGH CT.
Century 2535
Does anyone have any sugestions where the best place to mount a level indicator would be on my 2535. It seems that my options are limited, Any ideas?
Thanks Steve
/ Level Indicator Mounting #2
Hi Steve,
I mounted mine on the top of the "dash." It's not level, but the meter can be leveled on flat ground. Visibility is pretty good there and it doesn't interfere with the hood operation. Good luck!
Jonathan - How did you attach it? - I was hoping that there might be better spot.
Steve
/ Level Indicator Mounting #4
Hi Steve,
Sorry to take so long getting back. I just used the stick on mount, putting the meter just to the left of the point of the dashboard. Then I leveled it. Best I could come up with--not very good but it works.
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
Ford 555 (A64911)
Ford 555 (A64911)
20' CONNEX BOX (A67714)
20' CONNEX BOX...
(4) ForeRunner 12-16.5 N.H.S. Tires (A64912)
(4) ForeRunner...
Hay Van BL-96 3pt Hay Grabber (A64912)
Hay Van BL-96 3pt...
