Flail Mower Let's talk flail mowers
   / Let's talk flail mowers #5,931
I am not real picky about the lawn, as long as it is green and reasonably even after it is cut I am happy. I want to use the flail to cut the biggest part which is about 6 acres if I can just get it to stop leaving the uncut tire strip, not looking for a golf course cut.
Try mowing more often,,
if the grass is the correct height when you start,, it will look great after cutting,,
I mowed 4 acres yesterday,, not a tire track,,,
   / Let's talk flail mowers #5,933
If you mow in a spiral pattern that will also let you overlap and eliminate any flattened grass and the grass will recover quickly.
   / Let's talk flail mowers #5,934
Hard to believe you guys use your flails to do your yards, I've a little 48" JD rider for that. If I were to get out my flail, and my L3540 tractor that runs it, to do my yard, I'd have tire tracks and torn up spots all over the place!
   / Let's talk flail mowers #5,935
My flail is almost always connected to the deutz. Open gate,start tractor, do some laps, done.
   / Let's talk flail mowers #5,936
Depends on the yard Ours is about 6 acres. I don’t use the flail in the dogs yard, about 28x20.
   / Let's talk flail mowers #5,937
The setup: Four acre yard to mow on a 100F summer day. Choices: 72" Hustler Super Z open station zero turn mower or 84" flail on Case 55C with A/C cab. You do the math. :) Vic
   / Let's talk flail mowers #5,938
The A/C cab is nice, but a 72" Hustler would likely get the job done quicker, and better.
   / Let's talk flail mowers #5,939
1. I am not using tractor. Side by side.
2. I have **** for grading and 1.25 acre of wetland. I pulled mowers out of mud pits several times too many. And, had to wait till mid June to actually be able to mow where puddles were, while grass is waist high by then. With side by side and 59 inch tow behind, I am done twice as fast and finally mowed over puddles and mud pits.
Not every mower is a tractor tow behind Godzilla, tearing lawn apart. I have zero tracks after mow.
   / Let's talk flail mowers #5,940
Ok ok, I guess that all makes sense.. my "yard" is maybe a little over an acre without a lot of real open space , lots of stuff to go around. I got a couple fields I do with the flail and I guess I don't really care if they get tore up a bit.
2016 Komatsu WA380-8 Wheel Loader, S/N 15080, PIN# KMTWA13OCGA015080, Turbo Diesel Engine, Komatsu (A59076)
2016 Komatsu...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A55973)
2012 Kenworth T800...
WACKER NEUSON SM120 STAND ON SKID STEER (A52709)
WACKER NEUSON...
